Results 1 to 9 of 9
Thread: 28' Solar cover for 33' pool???????
    Mar 2013
    Central Iowa
    171
    I just found a 28' solar cover, brand new, listed on Craigslist for $50.00. The box in the photo shows it is a "Solar-Cell Sunblanket".
    My question is.....our AGP is 33' and this is for a 28' pool. Will it be effective or does the whole pool have to be covered for it to be able to hold the heat in?
    Is anyone familiar with this brand? Good or not? It looks blue in color, not clear.
    Does a solar cover go bad just sitting on a shelf? The ad says it was a back up and has not been used. (however, this is Craigslist)
    What do you think?
    2014 Used 33'x54" Wilbar Morada,deep end approx 28,800 gal.
    Hayward S180T1580S pump/filter combo,
    Pentair Aqualuminator light/return, Aquabot S2-50
    TF-100 kit, Initial fill with pond water
    South Central Iowa
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: 28' Solar cover for 33' pool???????
    I'd think 85% of surface area coverage would be fine. Cover should be fine if unused. They break down due to sun and chemicals and handling. For 50 bucks, I'd try it.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I'm going to disagree - sorry Woody... solar "blankets" work best at holding heat IN. The heat gained during the heating of the day. With that big of a gap around the perimeter - I don't see how it would work as well... jMHO
    38,521
    True the main advantage of a cover is reduced heat loss due to evaporation. So saving 85% of the heat is better than nothing. But I do not know how much a correct size cover would cost.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Mar 2013
    Central Iowa
    171
    The 33' round solar covers that I have found are usually over $200 and closer to $240ish. So this would be a huge savings, however, if it will not be effective, then maybe not worth the bargain.
    Any other input?
    THANKS for the help!!
    South Central Iowa
    Jul 2012
    Chicago, IL
    358
    It definitely won't work as well as a 33', but if the choice is between a 28' and nothing, I would go with the 28' for $50. Otherwise, I'd put that $50 towards the 33' if you are inclined to get one at some point anyway. It is a good deal relative to a 33', 25% of the price with 85% of the coverage.
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by Pauls234
    A 28' cover will only cover about 72% of a 33' pool. You can't just compare the diameter because surface area increases with the square of the radius. 28/33 is 85%, but 282/332 is only about 72%.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I just cut down a 20' x 40' solar cover to fit on my 27' round abg pool that I got off craigslist for $40. It seems to help with the temp, definitely helps keep it cleaner and cuts down a little on chlorine consumption. The upper surface is filthy with pollen and road dust in just a week of use.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    solarcovers.com has an 8mil blue 33' for $143.99.
    Supreme 12mil blue is $173.99.
    $200+ would be for the clear/black/"space age" @ 12-16mil
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
