Thread: Hard Plumb 24' round pool
    We are wanting move our filter and pump away from the pool so that we can free up our yard. Does anyone have step by step directions on how to do this? Also we heard that you can bypass the skimmer to clean the pool has anyone done this before.
    Tanya
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Hard Plumb 24' round pool
    Welcome to tfp, tpeters
    It is hard to give step by step instructions without some more detail provided by you. A picture showing your pool and where you want to put the equipment would be helpful. Also, how many skimmers and returns you have...and if you have any other pool features.
    Quote Originally Posted by tpeters
    Have you used a skimmer vacuum plate? On my pool I use a separate pipe with a nipple on it that is valved.
    Feb 2013
    Worcester, MA Suburb
    53
    Hi Tanya.
    I just did this with my new pool recently. My pool equipment pad is about 40 feet from the pool, and I buried all the water lines under ground about 12". I used hard PVC the whole length. In order to do this at this distance, I needed to upgrade to an in-ground pump (Hayward Superpump). The pump is working great at this distance and I like not having all the equipment out near the pool. The only difficult part was digging the trenches, and even though I rented a trench digger from Home Depot, the amount of stones and rocks in the yard made this a chore. But it was well worth it.
    My New Pool
    Dino
    Premier (Esther Williams) 24' x 52" Round AGP (13,500 gl.), Hayward 24" Pro-Series S244T Sand Filter, 1.5 HP Hayward Super Pump, AquaRite SWG, AquaComfort ACT-1100 Heat Pump, Jandy/Zodiac iAqualink Automation System with iPhone App, Aquabot Pool Rover S2-40
    My New Pool
