Thread: Ecostar Pump Failure
    I have a 2 year old echostar 3400vsp pump that was giving a "pump has stalled" error. I tried to rotate impeller by hand to see if it would turn freely and it didn't, felt like it was catching. I figured that it was the bearings that had gone bad and picked up replacement bearings to replace the existing ones. Once i opened the motor i realized that the bearings were fine and saw that one of the magnets on the shaft became unglued was broken in several pieces. Does anyone know if the magnets can be replaced or am I stuck with having to buy a new pump motor.
    17x30 free form gunite, 14,500 gal, 3.5' to 5.5', Hydrazzo, Hayward Ecostar pump, Hayward Heat Pump Pro, Aquarite 40 k gal SWG, Sta-Rite System 3 53sf DE filter, Polaris 280 w/Hayward 3/4HP Booster pump, TF100 Test Kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Ecostar Pump Failure
    Welcome to tfp, uofd90
    I do not have an answer for you, but hopefully someone who does will soon chime in
    It is very unlikely that the motor can be repaired.
    Any chance you are still covered under warranty? That sure sounds like a manufacturing defect to me.
