Results 1 to 7 of 7
Thread: partial drain/refill technique to lower CYA
    May 2013
    Collierville, TN
    10
    So I am attempting to convert to the BBB method with my pool. The previous owners used trichlor so the CYA is measuring over 100(about 60 with the 1/2 pool 1/2 tap technique). I guess I will go ahead and do a partial drain/refill and I am looking for suggestions on how. I do have an L shaped pool so I was considering putting the hose in the shallow end and draining exclusive from the bottom drain in the deep end.
    Question- will the new water sit on top of the old water or does it depend on the temperature of each? Should I get my chlorine real high and stop the water circulation to attempt this? Is there a better suggestion in general?
    +/-25K gallon L-shape vinyl liner inground
    sand filter
    Taylor FAS-DPD K-2006
    Polaris 360
    junior level BBB
    Re: partial drain/refill technique to lower CYA
    I wouldn't worry about the water mixing or not mixing too much, it will still work either way.
    The other option is a little more complex, but uses slightly less total water. That would be by draining 18" and then refilling, and repeating a couple of times. However to do that you need to be able to draw water from only the main drain, otherwise you will lose prime.
    May 2013
    Collierville, TN
    10
    and when you say "main drain", that's the bottom one?
    sand filter
    Polaris 360
    junior level BBB
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Yes
    May 2013
    Collierville, TN
    10
    So why out of curiosity would I just do 18" at a time instead of doing it all in one whack?
    sand filter
    Polaris 360
    junior level BBB
    38,295
    Because it can be a bad idea to drain a liner pool ... it may shift or be damaged.
    May 2013
    Collierville, TN
    10
    ok, that makes perfect sense. thanks
    sand filter
    Polaris 360
    junior level BBB
