Thread: Iron stains
    Poolkim's Avatar
    Jun 2011
    Canton, Michigan
    8
    Iron stains
    Ok - I confirmed my ring around the pool is indeed IRON ... it easily went away with the Vitamin C tablet. Should I just use more tablets to remove the rest of the ring or what?
    9800 Gallons IG Fiberglass
    Cartridge Jandy CT100
    SWG Jandy Apure700
    Max HP pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    Re: Iron stains
    No, you'll need to buy pounds of ascorbic acid, and let FC drop to nothing. Which means you'll need an algaecide to keep it from blooming, and when it's all done, you'll need a sequestrant. Start reading here: ascorbic-treatment-to-rid-pool-of-metal-stains-t2298.html
