Thread: Available Chlorine Question
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    I just bought a case (4 gals) of Liquid Chlorine from Rural King for $10.00. The label reads as follows: Available Chlorine - 15%. Sodium Hypochlorite - 12.5%. Which description do I use when adding Chlorine to my pool? Is it 15% or the 12.5%. Second Question: The pool calculator lets me input the 15% reading up in the FC column, but it does not give me the 15% option down in the "Effects of adding chemicals"; thus, I am assuming that I should use the Available Chlorine option at the 12.5% instead of the 15% - is this a correct assumption?
    18,000 gal, 18x32 IGP, vinyl liner, 3 to 5.5ft depth. One inlet/skimmer (Aqua Genie), one main drain. Hayward Pro Series Sand Filter w/filtration rate of 20 GPM/FT, Two-Speed Pentair Whisperflo 1 HP pump, Natural Gas Hayward H200 pool heater, Aquabot T2 (200 Series) Robotic Pool Cleaner (my best friend), Automatic Electric Pool Cover (2nd best friend).
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Available Chlorine Question
    You have 12.5%
    h2ctpdjl's Avatar
    Jul 2008
    Indiana
    252
    Thanks for the quick response.....greatly appreciated
