Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: My Question/problem of the day...
    May 2013
    Norman, Ok
    35
    I have a ton of questions, but hate starting a new thread for each of them, so I'm going to have one thread that I will ask most of them here.
    FINALLY got my test kit, and here are this afternoon's numbers-
    FC - .32
    CC - .08
    PH - 7.4
    TA - 90
    CYA 80
    So according to the calculator I need to add a small amount of washing soda and chlorine. Water has really cleared up the last several days, but we still have a green shade...is shocking a given when opening a pool after having it dormant for the winter? If so, does it appear okay to start shocking?
    As always, thanks for the replies and help.
    18 x 30 IG vinyl "sports pool" 16k
    Hayward pump & sand filter. Polaris cleaner (older model) & booster pump.
    K-2006 test kit
    38,295
    Re: My Question/problem of the day...
    What test kit? The ones we recommend do not go to 2 decimal places.
    Leave the pH and TA alone, they are fine. Although you CYA is a bit high so a 30-40% water change would not hurt.
    Actually if you are going to start the shock process, you may want to lower the pH a bit before you start.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    Quote Originally Posted by RowdyC
    FC - .32
    CC - .08
    PH - 7.4
    TA - 90
    CYA 80
    Typo, maybe? You sure you don't mean FC 3.2? Too low for 80 CYA. Never let it dip below 9. Ever.
    Your pH is just fine where it is.
    Jun 2012
    Howell, NJ
    977
    If you're using the K2006 or TF-100 those should be 3.2 and .8. Either way, the chlorine is too low, and the CYA is on the high side, especially for shocking. I don't see a CH number. Did you test for that? I would leave pH and TA alone. The TA is on the high side of recommended, and pH will rise on its own. Also, when doing the chlorine test you can use the 10 ml sample (provided you are using the TF-100 or K-2006.)
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    May 2013
    Norman, Ok
    35
    I'm using my NEW K-2006 (I'm excited). I was watching a YouTube video from "swimjim"? And I was doing math based upon their stats. eg. FC 16 drops x .02, and that is where I got .32
    I did not do the CH test but will try and get to that one before dark. The CYA test seemed fickle, so I think I'll try the 1/2 & 1/2 test next time.
    So when is the best time to test water? And should I test again before making adding anything? Also, are their better videos to watch the use of the K-2006?
    K-2006 test kit
    38,295
    If you started with 25 ml of water then you multiply by 0.2, but you should just use 10 ml of water and multiply by 0.5.
    Test anytime as long as the pump has been on for an hour. Then add what you need based on that test.
    There are videos for all the TF-100 tests which are basically the same thing:
    http://www.youtube.com/user/tf100testki ... sults_main
    Isaac-1's Avatar
    SW Louisiana
    6,711
    What Jason said, testing to .2 with a 25 ml sample is just wasting reagent .5 resolution is plenty to FC or CC, chances are you can't repeat to .2 from 2 different samples.
    May 2013
    Norman, Ok
    35
    Today's numbers:
    FC - 9
    CC - 0.5
    TA - 90
    PH - 7.6
    CYA - 75-80 - I hate this test regardless of how many times I re-use test agent.
    CH - 280
    Several questions today -
    #1. What's the school of thought about shocking before/during/after rain storms?
    #2. Hooked up the vacuum and pump lost prime momentarily and then returns started blowing "dirt/filth" back in pool? WTH? I did shut off pump, back washed (very dirty), rinsed, primed and started again, all seemed fine.
    K-2006 test kit
    Jul 2012
    Chicago, IL
    356
    To answer your questions on shocking... no it is not a given that you need to shock upon opening for the season, nor do you need to shock just because it has rained. I'm on my second season of a pool and have never gone through the shocking process.
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    May 2013
    Norman, Ok
    35
    Started the "shock process", used pool calculator and added what it suggested based on my readings.
    Brushed, waited an hour and fifteen minutes and my target FC was 30 but actually read 39.
    Pre shock- FC 5, CC 1, TA 90, PH 7.4, CYA 80, CH 280
    Is one of my readings off? Or was my math off adding 710oz of bleach?
    Just a little nervous with such a high FC number.
    K-2006 test kit
    Jul 2011
    St. Paul, MN
    244
    When I plug your info into the pool calculator, I get that you should have added 933oz. of 6% bleach to get from 5 to 30 ppm FC for an 18k gallon pool.
    Seeing that you overshot your target, it could be that the bleach you are using has a higher concentration than what is listed on the bottle, or your pool isn't actually 18,000 gallons, or the bleach didn't fully mix before you remeasured.
    Either way, no need to worry about 39ppm with a CYA of 80.
    20'x40' Oval 27,000 gallon Vinyl IG, Coverstar Auto Cover
    Hayward MaxFlo SP2303VSP, Sta-Rite PLD50 30 sq. ft. DE filter
    Rheem 266,000 btu natural gas heater
    Dolphin Nautilus Plus with Clever Clean
    TF-100 testkit w/ Speed Stir
    May 2013
    Norman, Ok
    35
    It's been a long time since I barely passed college chemistry...but it appears that the bleach is 8%.
    Thanks for the re-assurance that I'm not melting PVC pieces etc. I'll guess that it's not mixed as well as it should be, and test again in an hour!
    THANKS!
    K-2006 test kit
    May 2013
    Norman, Ok
    35
    1.5 hours later and FC is 36. Should I just let it drop to the 30-31 range and then concentrate on holding it there?
    K-2006 test kit
    Jul 2011
    St. Paul, MN
    244
    Yes, that's a good plan.
    May 2013
    Norman, Ok
    35
    9+ hours and the FC is still holding at 36, got lucky with a very cloudy day. We've brushed 2 times and I'm going to go brush again in the dark (sounds like a country song...a bad one, but), if FC holds throughout the night, and water is clear,can I consider this shock therapy done?
    K-2006 test kit
    Jun 2012
    Howell, NJ
    977
    If CC<.5, OCLT<1ppm, and the water is clear, you are done shocking.
    John
    May 2013
    Norman, Ok
    35
    Q of the day: I have things floating on the water surface, that appear to be tree pollen. It's been doing this for several weeks. When I run the filter for 12+ hours it pretty much eliminates it, but comes back the next day. If this is indeed tree pollen (cottonwood), than it is what it is, but if its a sign of some sort of algae, I'd like to jump on it ASAP. I do live in a neighborhood with lots of big trees, with several cottonwoods and Bradford pears.
    My chemicals are all in the normal range (according to pool calculator) and have been with the exception of a 3 day period when we were out of town. CC went up to 1.5 and FC dropped to below 2...haven't shocked since that drop.
    K-2006 test kit
    Jul 2011
    St. Paul, MN
    244
    Can you post a set of test results?
    I've found it doesn't hurt to bring your FC up to shock level if you think there's any chance its algae.
    May 2013
    Norman, Ok
    35
    FC - 9
    CC - 0.5
    TA - 90
    PH - 7.5
    CYA - 75
    CH - 280
    K-2006 test kit
  20. Back To Top    #20
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,387
    If it is collecting at the waterline and in the depressions in the floor but not on the walls it is probably pollen. Pollen does not feel slimy and comes back daily even with high levels of chlorine.
    Love TFP? Become a
    TFP Supporter!
