Results 1 to 7 of 7
Thread: Pool Still Clowdy after ~100 lbs of Shock
    I have a 20x40 in ground pool. There is a leak somewhere, possibly in the lines. I had trouble keeping the water clear last year, so around August I gave up and stopped adding shock, running the filter, etc.
    This spring I hired professionals to clear up the pool. They have been here every day but Sunday for over a month, adding 4-6 pounds of shock to the pool most days. They have vacuumed to waste, the pool is free of debris, and yet while the pool is blue, it is still cloudy, and you can't see the bottom.
    They have tried metal removers and had it tested for phosphates, and are totally stumped. They chlorine just keeps dropping to zero, after only a day or two.
    We think the leak may have something to do with it (I have to run the hose for about an hour every other day or so, mostly because we are backwashing every day), but we don't know what it would be. We just changed the sand in the filter 2 years ago.
    Any help or suggestions would be greatly appreciated. Thanks.
    Feb 2008
    Denton, TX
    5,061
    Re: Pool Still Clowdy after ~100 lbs of Shock
    Welcome to TFP!
    You need a good test kit. Please get yourself a TF-100 or a Taylor K-2006 from tftestkits.net. We need test results for FC, CC, CYA, pH, TA, and calcium hardness. Once we have those, we can start dialing in your problem.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Quote Originally Posted by insightz06
    Educated guess: They've been shocking with Tri-chlor. Which raises the stabilizer too high too fast. Which means whatever chlorine is in there is ineffective, so they need to add more "shock"...which raises the stabilizer too high too fast, which means whatever chlorine is in there is ineffective, so they need to add more "shock"... and so on in an endless, escalating, spiral of doom.
    Order a test kit - a proper test kit; don't be penny wise and pound foolish after all the money you've shoveled at that soggy hole in the ground - and start reading Pool School.
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    Yep, what they said^^ The best thing you can do for your pool is order one of the recommended test kits. The TF100 is the best bang for the buck. Link in my sig.
    As they said, once we get a full set of test results, we can dial in on the problem.
    You have come to the right place to conquer the problem
    Folks here will help you take care of your pool.
    You're done SLAMing when:
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Welcome! Once you read up in pool school I'm guessing you will be very upset with the "professionals"...(however I wouldnt take it out on the ignorant doing what they have been taught).
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Your suspected leak isn't the problem----------your pool people are.
    Oh yeah--Welcome!..............(and post your pool test results)
    thehowheels's Avatar
    Apr 2013
    SoCal
    120
    Quote Originally Posted by Richard320
    +1
    Let's assume "100 lbs of shock" was dichlor. According to poolcalculator.com, this will "raise FC by 74, raise CYA by 67, lower pH by 2.81, and raise Salt by 60".
    If "100 lbs of shock" was trichlor, it would "raise FC by 122, raise CYA by 74, lower pH by 6.52, raise Salt by 100".
    Or perhaps it was cal-hypo, "raise FC by 96, raise CH by 68, raise salt by 98".
    So pick your poison. +67 CYA, +74 CYA, or +68 CH. Any one of them is probably going to put you in a bad spot.
    Matt
    9k gallon, plaster, IG. Raised spa w/ spillover into pool. AO Smith Century Centurion / Purex Triton WisperFlo 0.5 HP, Hayward 1.5 HP (spa), Polaris 1-516-01 1.5 HP (blower). Hayward DE3620 36 ft2 72 GPM DE Filter, Polaris 145 cleaner. Pool built ~1980.
    Trouble-free, BBB since: April 25, 2013
