Thread: Replace rusted bottom rim on AGP
    I have an above ground pool that I received from a friend. After taking everything down to move it to the new location I noticed that all of the bottom rail pieces were rusted through and that we had broken one of the bottom plates. I have everything else ready except I really want to replace the rails that are rusted and the bottom plate. I do not know the brand of the pool. I believe that the pool is a 30'x15'. I have looked everywhere on it and have not found it. The rails are a metal rail around 7/8" to 1 inch across and the plate is 7"x5". I was wondering if anyone knew an online retailer that carries these parts. Thank you so much!
    Oct 2012
    Central Ohio
    180
    Re: Replace rusted bottom rim on AGP
    Do you have a picture of the pool wall?
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
