Thread: Need Advice - Kreepy Krauly tends to miss parts of pool
    May 2012
    Toronto, ON
    463
    In my pool the Kreepy Krauly doesn't do a good job of cleaning my shallow end which is the farthest point from the skimmer, which is where it is connected. I have tried adding a section of hose in the past but this still hasn't helped. Just a guess but I am wondering if one of the issues is that there is a jet near the corner and I am wondering if the jet tends to blow the KK away from the corner and back towards the deep end.
    Any advice on how to improve the coverage of your pool with a KK?
    Vinyl 18'x36' in-ground 100,000 L, Jandy Aquapure 1400 SWCG, Jandy Lite2 heater, StaRite System3 filter, Evac tube solar heating panels
    Pleasant Hill, Ohio
    1
    Re: Need Advice - Kreepy Krauly tends to miss parts of pool
    I've had the same type of problems and have found that removing a section or 2 for a half hour has helped get closer to where it is connected. It won't get the far end then, but it seems to get closer to the connection point without the hose getting all twisted up. Hope that helps.
    20,000 gal. vinyl inground, Hayward superpump 3/4 hp, Tagelus ta50 sand filter, Kreepy Krauly suction cleaner, TF-100 test kit
