Results 1 to 17 of 17
Thread: High Filter Pressure, Low Flow, Minimal Suction
    Feb 2011
    Cincinnati, Ohio
    106
    Just opened pool today. Problem is that I have cleaned filters three times already and each time I run the pump the pressure goes sky high in less than 10 minutes. After cleaning this last time it never went down. I just sprayed them with a nozzle on the hose. I had a company close pool last year and they took filters with them and acid washed them. I do have alot of algae I'm trying to clear but to me it should still take a little while to get the cartridges dirty before pressure shoots up.
    Does high filter pressure create minimal suction at the skimmers and create low flow so that the swg would not even work if i wanted it to right now?
    Could a suction side leak at the pump cause this?
    What else should I look for?
    Thanks.
    18 x 36 IG Vinyl Liner 28K Gallons
    Pentair Intelliflo VS+SVRS, Pentair CC + 420 Cartridge Filter, Easytouch CP with IC40 SWG
    2" Suction and Return Lines - 2 skimmers, 6 returns
    Dolphin Diagnostic Advantage Robot
    38,415
    Re: High Filter Pressure, Low Flow, Minimal Suction
    If you have a lot of algae, the filter will clog quickly ... that is what they are designed for. Yes this will lower the flow rate and suction from the skimmer and may not be enough to keep the SWG on ... but we generally recommend not using the SWG when performing the shock process (You are doing this right??? Exactly how it is described in Pool Shool???)
    suction side leak can result in lower pressure, not higher pressure. Is there air in the pump?
    Feb 2011
    Cincinnati, Ohio
    106
    Just turned pump on after spraying off filters. Running at 2150 rpm at 22 psi and won 't even keep running. It kicks out. The flow red light is on the intellichlor but I'm not trying to use it anyway because I am following PoolSchool shocking instructions. Just kinda hard with no pumping/filtering going on.
    Can I run without my cartridges in to make sure there is nothing else going on?
    There is a little air in pump but nothing out of the ordinary. I know ideally there is none. I may need a new oring for one freeze plug but I just wanted to make sure that wasn't creating all pressure issues. I didn't think it could.
    38,415
    Another struggle due to the dumb SVRS pump ... seen a lot of these recently.
    Also, not uncommon to see an air bubbling in the top of the pump when running on lower speeds.
    Yes you can try running without the cartridge to see if that is causing the flow restriction.
    Feb 2011
    Cincinnati, Ohio
    106
    just wanted to make sure that would not blow anything up if I did that.
    Until you get it fixed you can also run in recirculation. This won't filter (obviously) but will still provide the mixing that will help with the shock process. At this point this is probably more important anyway. If pressure is still high in recirculation then you know you have a blockage - somewhere on the pressure side of the pump.
    Remember from pump curves that flow rate is inversely proportional to pressure (not 1:1 though).
    38,415
    Quote Originally Posted by aomagman78
    Most all cartridge filters do not have multi-port valves with a recirculation setting.
    Feb 2011
    Cincinnati, Ohio
    106
    I tried it without cartridges and it runs fine. Almost 0 psi when at 2150 rpms and only like 4 or so at almost 3000 rpm. No air in pump either.
    Put them back in and once again pressure problem.
    I have no re-circulate.
    How can I continue on the shock process with no filter. Will it harm the filter or anything else to run with no cartridges to at least get all algae exposed to chlorine and killed at this point?
    Then I can filter everything once dead?
    38,415
    I would suggest doing a thorough cleaning on the cartridge (or replace it) as apparently it is pretty clogged up ... might need soaking in TSP and then acid.
    Meanwhile, run without the cartridge and follow the shock process.
    EDIT:
    re-how-to-clean-a-cartridge-filter-t4465.html
    Feb 2011
    Cincinnati, Ohio
    106
    New Cartridges and Dead Algae
    Merged by moderator. Please keep your related topics together. Thanks, jblizzle
    Still going through the shock process. Will probably be finished with it after today as my numbers from last night and this morning looked almost good to go. My problem is that I've been running the pump mainly without filters because my filters caused the pressure to be too high. Therefore I bought a new Unicel set yesterday that should arrive tomorrow. I had a lot of algae in the pool after opening and it is all dead now but i'm leary of sticking this brand new set of filters in there to get it out. I don't want to ruin them. Do you think they will be okay if I make sure to wash them several times?
    My original ones only last two seasons. I want to make sure to get much more use out of this set. I soaked my current ones overnight in acid then washed. When I put back in my psi was still higher than it should have been. I could only run filter about 2 hours before getting too high of psi therefore I pulled them again. Trying to limp through this and finish cleaning with old cartridges to save the new but don't know if it will get it done or not.
    38,415
    After you acid washed, what was the initial pressure? How high did it rise in 2 hours?
    If you are clearing up algae ... this sounds completely normal to have to clean them a LOT ... the downside of a cartridge filter when you get algae.
    Using the new cartridge will not hurt them ... this is what they are designed for. Just make sure you clean them when the pressure goes up 25%.
    Feb 2011
    Cincinnati, Ohio
    106
    Pool running at 2100 rpm after cleaning at 8 psi. Went up to over 20 within two hours and the low flow light came on the Intellichlor (not using during shocking I just use that as my indication that my flow is too low to be doing much) and suction at skimmers was not good nor return flow from returns.
    My cartridges don't look anywhere near as bad as some others I've seen pics of. Just gray. Only thing that confuses me is that when I sprayed them off after pulling again I didn't really see nasty water coming off them so I don't know why psi climbed so high. Maybe dead algae is hard to see on the filters when washing off????????????
    I will try to put them back in after work and see what psi i get. Then I'll decide about using the new carts or not.
    38,415
    So the acid wash seems to make a huge improvement in the initial clean pressure right?
    Again, sounds like you just have a lot of stuff in the water that the filter is catching.
    I am guessing you would see the same kind of rapid pressure rise if you use the new cartridges as well.
    Feb 2011
    Cincinnati, Ohio
    106
    I shouldn't need to use acid everytime though right?
    38,415
    No. That was just to remove any calcium that may have been on the cartridge. Did you soak it in soap before the acid like that link I posted?
    Feb 2011
    Cincinnati, Ohio
    106
    To be honest, no I did not because there were no oils or anything like that on there that I thought would cause them to be ruined by using the acid. If it is just dead algae at this point shouldn't I just be able to hose off?
    Or should I soak everytime?
    38,415
    IF there were any oils, then not using the soap to soak before the acid could cause problems.
    At this point you should just have to hose them off.
