Results 1 to 9 of 9
Thread: Strategy/Order to attack algae
    Jul 2011
    New Orleans, LA
    26
    Hey guys
    After weeks of hard rains I guess my water has been diluted to where the SWG was ineffective. (Where does it go?)
    Got a hint of green a couple days ago, last night I added bleach to FC 15 shock level (40 CYA).
    This morning's readings on 25k gal plaster
    FC 11
    CYA 40
    pH 8.1
    TA 140
    Salt 2200
    So I know I need to add salt, acid and more bleach until it clears up. The question is whether I can do it all at once?
    Bleach is going in now... should I go ahead and run up the salt at the same time too? Should I wait on the pH until the algae is gone or try to tackle it now?
    Do I really need the "algae control" that the pool store is trying to sell my wife (before adding the salt)?
    25k gallon rectangular, Cartridge filtered
    New AquaRite T-15 cell and board
    IG Plaster, No idea of pump size/flow rate
    TF-100 kit with the K-1776 salt kit
    Polaris 280
    Still learning, but I've been to pool school!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Strategy/Order to attack algae
    pH first. Then run it up to shock level. Continue the shock process. If you caught it early, it shouldn;t take long.
    Once you've passed all three tests to know you're done shocking, fill your sock with CYA and hang it in front of the return. Add salt and turn the SWG back on.
    The cost of the bleach will be much less than the cost of replacing the burned out SWG.
    Jun 2012
    Howell, NJ
    977
    Just want to note that with a FC >10, the pH test can be inaccurate. It can read falsely high.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Xenon
    Not if you maintain an appropriate amount of FC for your cya level.
    Jul 2011
    New Orleans, LA
    26
    Quote Originally Posted by JohnN
    Yeah, I panicked a little this morning...
    Had my pH in the sweet spot yesterday then tested again this morning after maintaining a high FC overnight (and having a blue pool this am) and it the reading was 8.2+
    I decided not to add any acid and wait it out until after work today, see if the some of the FC burned off in the sun and revisit it. Now I'm glad I did. I didn't remember that tidbit. There are lots of these
    Follow up question: Pool store says I have high metal content in the water. In particular, copper. Is this something I should be concerned with? Best method to reduce it?
    Polaris 280
    30,426
    Partial drain and refill to reduce it. Do you know how it got there? It almost never naturally occurs.
    Jul 2011
    New Orleans, LA
    26
    No idea. He said it could be from debris in the water (which I have some of some my Polaris booster quit) and tried to sell me "metal free" which would reduce it. I thought I'd check here first.
    FC is down to 8 after a full day of sun. I brushed the pool again for any algae I may have missed last night. I think I'll bring it back up overnight then tweak the rest. Hopefully she passes the tests in the morning.
    I should add the CC is .5 or less and clear
    Polaris 280
    38,371
    Debris would not add copper. Copper is usually either from the use of some mineral system or the use of certain algaecides ... neither of which we recommend.
    Jul 2011
    New Orleans, LA
    26
    And I can promise you that I haven't added algaecide and have no mineral system at least since July of 2011 since I've owned the house. Then again, I've never tested for copper either, so I guess it could still be in there.
    Polaris 280
