Working on gathering pics of the install, but don't have time at the moment. I do have a couple questions. Am I missing something, or maybe this is common knowledge?... but uhhhh... I can't seem to find anything in the manual or otherwise that says how high to fill this pool? Common sense tells me that the water line needs to be somewhere in the middle of the skimmer, but how high can I go before it's "too much" and how low is "too low"???
I acquired an Intermatic Timer for the pump in which I will run out to a plug. I bought a 13amp cord (figuring that the pump has an 11amp max rating), that I feel should be sufficient. Am I correct here?
I also have a stenner pump. Should I plug this into the same plug as the pump (so that I can adjust it to run for as long as the pump does), or can I even dial it down that low? OR... should it be on a separate plug and attached to it's own timer?
