Results 1 to 9 of 9
Thread: Few questions on new build...
    Working on gathering pics of the install, but don't have time at the moment. I do have a couple questions. Am I missing something, or maybe this is common knowledge?... but uhhhh... I can't seem to find anything in the manual or otherwise that says how high to fill this pool? Common sense tells me that the water line needs to be somewhere in the middle of the skimmer, but how high can I go before it's "too much" and how low is "too low"???
    I acquired an Intermatic Timer for the pump in which I will run out to a plug. I bought a 13amp cord (figuring that the pump has an 11amp max rating), that I feel should be sufficient. Am I correct here?
    I also have a stenner pump. Should I plug this into the same plug as the pump (so that I can adjust it to run for as long as the pump does), or can I even dial it down that low? OR... should it be on a separate plug and attached to it's own timer?
    27' Round Sharkline Venture 17K Gallon AGP
    Pentair SD80 26" Sand Filter
    Pentair Dynamo 1.5HP Dual Speed Pump
    45MPHP10 Stenner Pump
    Aquabot Pool Rover Jr.
    Jun 2012
    MA
    347
    Re: Few questions on new build...
    What does run out to a plug mean? I would not use an extension cord with a 1.5 hp pump.
    Quote Originally Posted by 1380ken
    i was going to run an outlet out from the timer, so that the 2 plugs would be on that timer and whatever was plugged into that would be controlled by that timer... that not a good idea?
    mas985's Avatar
    Pleasanton, CA
    11,737
    I believe the Dynamo (AGP pump) comes with a plug and it isn't a very high current motor (SPL rated) so I think that is ok.
    Normally you would fill the pool to mid skimmer but if you refill manually, you can go a little higher. You want to leave enough room at the top of the skimmer to allow debris to float into the skimmer. So at least an inch or two.
    The Stenner adjustment depends on the model # so I would check into that before deciding how to wire it.
    Mark
    Quote Originally Posted by mas985
    I didn't get the package offered by PSW, so mine did not come with a cord on it... hence my reasoning for getting a 13amp cord...
    mas985's Avatar
    Pleasanton, CA
    11,737
    Well they do come with the cord as well so it shouldn't be an issue:
    http://www.amazon.com/Pentair-Dynamo-1- ... B007JJYU3S
    Mark
    Oct 2012
    Central Ohio
    180
    Yes wiring up an outlet is a good idea.Although you may want to run 12AWG wire,it's good for 20amps.
    Rob
    Cozumel AGP 24' 14,700 gallons
    Pentair Dynamo 1.5 hp pump
    Sta-rite Cristol-Flo II 2.3sq.ft. sand filter
    SWCG,Uni-bead liner
    Borates
    TF-100 Testkit....$68,cheap insurance for a trouble free pool season
    Quote Originally Posted by CB
    since it won't do any good to have a separate outlet for the pump AND the stenner together, i'm just going to hard wire the pump into the timer. the line itself to the timer is 10/2, i do have some extra 10 and 12... but it looks like i'm going to have to get a separate timer for the stenner, so this just seems like an easier solution to it all...
    i'm also wondering if i should start off my shock process with the bags of shock instead of just straight bleach, so that i don't have to add as much CYA... anyone have an idea how much CYA is in a bag of shock?
