Results 1 to 12 of 12
Thread: New House , New Pool, Progress and Questions!
    May 2013
    lol
    3
    ow-
    ojmiijmi
    22,553
    Re: New House , New Pool, Progress and Questions!
    The best way to get the debris up is to vacuum it to filter and then backwash it out when it's time to backwash.
    The TA test isn't affected by high FC but the pH is. Still I wouldn't worry about testing either until you're completely done shocking and have passed the OCLT.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Vacuum the recirculating stuff and fix the Ph when your FC drops below 10.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Great first post!
    You should've started posting pictures earlier, so we could watch the transition!
    Nov 2010
    South Central Kentucky
    283
    Why vacuum that junk into the filter and not just to waste? At least for the initial passes. I've vacuumed to the filter in the past but was told to waste was a better option.
    15x32 vinyl liner, 14,400 gal, 1.4hp Centurion pump, 3/4 hp booster pump, Hayward Pro Series S244T Sand Filter, Hayward H200 heater (digital readout)
    Aqua Rite Electronic Chlorine Generator, Hayward Phantom cleaner, TF 100 test kit
    Pool School, Pool Calculator
    30,432
    Maybe, maybe not. I have a VERY large filter and a very precious source for water. Much better for me to filter into my big filter and then backwash.
    I vacuum to waste at about 90 gpm and my well is capable of producing 2 gpm. If I vacuum for 15 minutes, that's about 12 hours of well production,
    Each case is different.
    Nov 2010
    283
    Makes sense. I'm just filling from a outdoor hydrant, didn't think about other water source issues.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Also depending on the size of the leaves they may get trapped in the skimmer basket or the pump basket and not have to be backwashed at all anytime soon.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    May 2013
    lol
    3
    home.
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Yes, keep shocking until cc is .5 or less and the pool is clear.
    Dan D
    May 2013
    lol
    3
    So
    Nov 2010
    283
    You should probably bump the FC up to 13 to maintain the shock level for your current CYA level. I tend to fudge on the high side, closer to 14 or 15.
