Thread: Vermiculite Questions
    Feb 2012
    Maryland
    400
    If all goes well, my crew will be putting down the vermiculite this weekend.
    1. How soon does it "dry" or "cure"?
    2. Will rain hurt it after its dried? I need to measure and order the liner so will have about 2 weeks between bottom and liner drop.
    3. Can I walk on the vermiculite without leaving impressions?
    Thanks!
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    30,426
    Re: Vermiculite Questions
    Like concrete it continues to cure but should be pretty firm in 24 hours.
    If I suspected rain, I would cover it with a tarp.
    It's pretty soft but you can walk carefully on it.
    Nov 2011
    Moberly,MO
    1,010
    If there is rain in the forecast I wouldn't put vermiculite down. Built a 24x 50 had severe storms in the forecast for three days. Watched three skids of pool base fill the deep end. Had to redo the entire pool base pour all over. I would go ahead and order your liner then pour pool base to match.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
