Results 1 to 7 of 7
Thread: Starting up sand filter/ pump for first time...
    May 2013
    New Jersey
    28
    We're starting up our new to us Hayward sand filter and pump today. We have a small amount of debri in the deep end of the pool but its fairly clean. Should we start with a backwash cycle or filter cycle? Thanks! We love this site and appreciate all the help
    31,500 gallon IG w/vinyl liner, Hayward Pro Series S-244T Sand Filter w/ 1hp Hayward pump
    TF-100 Test Kit
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Starting up sand filter/ pump for first time...
    Go ahead and put it on filter for a little while - just note the PSI when you are running, when you are vacuuming, etc. Look for good pressure coming from the jets. Post back and describe what is happening.
    May 2013
    New Jersey
    28
    Will do, thanks!
    TF-100 Test Kit
    May 2013
    New Jersey
    28
    Well my husband went out to turn it on and it's staying on for about 2-3 seconds then its tripping the breaker. Any ideas why?
    TF-100 Test Kit
    May 2013
    New Jersey
    28
    Nm, he got it going! But our pressure gauge isn't working at all. Also, it seems that it's pulling water into the skimmer quickly for a minute or two then it slows down quite a bit then starts again... Not sure if that's normal?
    TF-100 Test Kit
    DaveNJ's Avatar
    Toms River, NJ
    520
    What is your water level? At least half way up the skimmer. Sounds like your sucking air into the skimmer (forms a vortex). All the valves on the suction and return side open?
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    May 2013
    New Jersey
    28
    Actually the water was a little low, maybe an inch past the skimmer opening, we've had the hose in abd its filling up. After a few minutes the pressure leveled out and it's been running normal for about an hour. Definitely seemed liked air was getting in. My husband's picking up a gauge today, for now it's running in filter and seems to be doing its job. I'll post psi later, thanks!
    TF-100 Test Kit
