Results 1 to 17 of 17
Thread: 60 Pounds of Dry Ice and a Swimming Pool!
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    323
    This is pretty cool! 8)
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Jul 2007
    Sahuarita, AZ
    278
    Wow... that doesn't seem very safe... he could have suffocated, passed out and disappeared under the fog covered water... Looks very cool though!
    Now what would this do to your pool chemistry???
    My Pool:
    12K gal IG gunite with 7' raised spa, gunite waterfall, PebbleTec Caribbean Blue finish, solar heating & in-floor cleaning system
    Equipment: Sta-Rite 300' Cartridge Filter, Intellichlor IC20 SWCG, Sta-Rite 400k BTU heater, Intelliflow 4x160 main pump & Sta-Rite 3/4 hp waterfall pump, EasyTouch controlls w/ wireless controller, TF-100 Test Kit w/ salt test.
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Thats it, I need a block of dry ice for my party.
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Oct 2007
    Valrico, FL
    537
    TA went to 200 and pH to 6.5!
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    What they fail to mention is that they are house sitting! That guy that got in is a complete idiot! He is very lucky he didn't pass out from carbon dioxide asphyxiation
    14x33 fiberglass freeform
    Variable speed Pentair intelliflo superpump
    420 Clean and Clear Plus cartridge filter.
    pool-school/pool_calculator , http://www.tftestkits.net/
    Mar 2007
    San Rafael, CA USA
    12,082
    I have used dry ice a few times for Halloween as shown in this image:
    I had some leftover and put it into my pool -- not 60 pounds, of course. It is neat to see, but it does lower the pH quite a bit (it doesn't actually change the TA -- for the same technical reason that outgassing carbon dioxide only raises the pH with no change in TA).
    Adding one pound of dry ice to 10,000 gallons would drop the pH from 7.5 to 7.0 if the TA is 100 and if all of the gas dissolved in water. 50 pounds in 10,000 gallons would drop the pH down to 5.4. If 10 pounds of their dry ice dissolved into 350 gallons in the spa, then the pH could have dropped to 4.6 which is quite acidic. In practice, about half of the gas escapes (bubbles away) with smaller quantities such as the pound or so I added to my pool (my pool's pH dropped from around 7.5 to 7.2).
    Richard
    Mar 2008
    Evans, GA
    323
    that effect was cool, but yes, I agree the guy that got in was a complete IDIOT! I missed the part about them house sitting. I would kinda be ticked if they did it to mine and it wacked out my chem levels!
    *~ Laura ~*
    TF-100 Test Kit
    whoozer's Avatar
    Apr 2008
    Acton Maine
    633
    Don't know if they were actually house sitting Just makin a joke
    Feb 2008
    Denton, TX
    5,061
    In some jurisdictions, that could be classified as a Haz-Mat incident. This is why I will always have a job as a RN.
    Apr 2009
    CT
    10
    Re: 60 Pounds of Dry Ice and a Swimming Pool!
    When the guy gets in and goes under water, he says that the water burns his eyes.... low ph...
    25000 Gallon
    Vinyl Liner
    Inground Pool
    Indoor Pool
    Hayward DE 3600 Filter
    Hayward 1HP SP2607X10 Pump
    So there is no change in TA just a PH drop? So how much does Dry Ice cost compare to Muriatic Acid? How long does the Dry Ice take to totally gas out? Handling the Dry Ice would be about as hazardous as pouring MA, but the fog show would much more entertaining.
    "Mountain Lake" Freeform Gunite Pool - 32000 Gal 3ft-8ft
    60sqft DE Filter,1.5HP Pump
    AQUAPURE SWG, 2 ft Sheer Descent, 25sqft Cozy Corner with Spa jets
    Nitro Wall Scrubber, Pool Buster Max
    Dry ice costs more than muriatic acid, and more significantly you can't store it at home for very long. If you really wanted to do this you would use bottled CO2 gas. CO2 is one of the ways to lower PH used by commercial pools.
    Rocklin, Ca
    467
    The effect is MUCH more dramatic if the dry ice is broken into many pieces. This increases the surface area exposed to the water.
    Do a search of "dry ice garbage disposal" on Youtube. cool stuff.
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
    I have actually been researching CO2 systems for PH control somewhat. I'm hoping to find a source for the phControl system made by the Clorinator folks as that would be a much cheaper solution then a CO2 system appears to be.
    Quote Originally Posted by LostBoyinVA
    You can get a controller and solonoid for less than $100-150 - I use one for a fish-tank. Google "Milwalkee pH SMS 122" or look it up on e-bay.
    ~45Kg Pool with attached Spa, NSP-72 DE, Minmax 400 Heater, Tahoe Blue Pebbletech, Jandy SWG via Aqualink RS-8, The Pool Cleaner (black)
    Pumps: X3 Hybrid Pump (switches to SPA), 2HP Spa (additional, when SPA is on), and a 1HP For Waterfall
    8, 4x12 Solar Panels on the roof of the pool-house (~12' up)
    CAPTAIN JAMES T. KIRK: "I'M SORRY. I CAN'T HEAR YOU OVER THE SOUND OF HOW AWESOME I AM" (Thanks to TFP!)
    Ok I was thinking about the cost factor. A gallon of Acid is costing me from Lowes rounded, but without taxes $7. A .5 drop in PH in my 32000 gallon pool is roughly half a gallon so $3. I have a Plaster Pool and a SWG so I get that much of a raise over a couple of weeks. The video claims a cost of $1 per pound of dry ice and the post above suggests a .3 drop in 10000 gallons per pound of Dry ice. So in my pool 1 pound is roughly a .1 drop in PH so I'd need $5 in Dry ice for a .5 drop in PH. So Muriatic acid is cheaper, but since Acid prices have doubled in the last couple of years, provided the dry ice price is acurate I'd say it may eventually be a cost effective alternative to acid. No I can't store it at home, but I have a grocery store that sells it 2 miles from my house.
    So I guess I need to pick up a 1 pound block and see how long it takes to disolve and take a PH Reading Before and after to verify the .1 drop in my pool.
    Quote Originally Posted by taekwondodo
    Thanks I'll look into it, but you then also need to buy a tank and pluming etc. So I'd suspect a DIY CO2 system for a pool is in the minimum $500 range. The Chlorinator is $140ish, I don't expect there PH Control system to be much more then that.
