Results 1 to 16 of 16
Thread: problem with AquaPro 500 heat pump
    dahncke's Avatar
    May 2012
    Indianapolis metro area
    32
    I purchased a new heat pump and cannot seem to get it working. It continues to error out with an HP (high pressure) code after about 5-10 min of operation.
    Anyone have any experience with these units? Calling for service, but really worried that we are off to such a bad start.
    Kayak Pool - 12 ft. x 24 ft. rectangular, 5½ ft. deep end
    Frog System, Sta-Rite-Modular Media Cartridge Filter, Pentair 1 H.P. pump
    AquaPRO Pro500 heat pump & Automatic AutoGuard™ Pool safety cover
    22,548
    Re: problem with AquaPro 500 heat pump
    The HP error should be on the freon side and that shouldn't happen as long as there is water flowing through the system. Have you checked to make sure you have water flowing through the heat pump to the pool? Make sure the bypass valve is closed if there is one.
    dahncke's Avatar
    May 2012
    32
    Yes, the water is flowing. When I shut off the pump, I get a flow error. So, it can tell that the water is moving. Called for service. No idea what the problem is. Hope it is not a sign of things to come with the unit.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Didn't the installer see this after they installed it?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    dahncke's Avatar
    May 2012
    32
    self install
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    You didn't by any chance plumb the unit backwards did you?
    Paul
    dahncke's Avatar
    May 2012
    32
    no, I am sure I didn't. I have a simple set up with only one set of drains and one skimmer.
    dahncke's Avatar
    May 2012
    32
    Anyone own one of these? Any insight on their reliability?
    Ft Lauderdale, Florida
    1,455
    make sure there's no obstruction on the discharge side of the fan, nor the evaporator coil around the unit. Blocked flow will cause this to occur as well. HP protection, high pressure, can also be due to improperf freon pressures in the unit.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    I have the AquaPro 500, and I am on my third pool season. I cannot help you with your problem, just wanted to let you know that I haven't had any issues with my heater (knock on wood).
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    dahncke's Avatar
    May 2012
    32
    On vacation right now, but the company sent someone out to swap out the unit. So, I am hopeful that will resolve the issue.
    Jul 2011
    844
    Any update on this?
    Bestway SWG
    dahncke's Avatar
    May 2012
    32
    Yes, we had a brand new unit delivered and installed. The new one has been working perfectly. It has cooled off here and the pool's temperature has remained delightful!
    Jul 2011
    844
    Awesome. Do you know which sensor was causing the issue?
    Bestway SWG
    dahncke's Avatar
    May 2012
    32
    No, once they knew it wasn't the sensor that detects low flow they said that the unit needed to be exchanged.
    Jul 2011
    844
    Ok, thanks. I was just trying to find out if there's something I should get ready for!!
    Bestway SWG
