Results 1 to 9 of 9
Thread: Pool light cover broke!
    Pocatello, ID
    29
    Well, this will be fun.
    I just removed my solar cover to do my first cleaning of the year and found that my pool light cover broke. There are now glass chunks of various sizes in the pool. This explains why I had a problem with main pool breaker tripping.
    My questions are:
    1) ****. What do I do?
    2) What could have broken it? It was intact when I placed the winter safety cover.
    3) can anyone recommend pool light covers which are quite a lot more durable?
    25K IG Vinyl / Pump: HP Tristar SP3207EE (as opposed to the confusingly different SP3205X7) / Filter:Hayward S360T2 (prev. SuperFlow PF-50) / Heat:6-panel FAFCO Ceiling solar heater
    Pocatello, ID
    29
    Re: Pool light cover broke!
    There's just enough light that I took a photo. this light looks different than many I've seen online. Does anyone recognize the type?
    Mar 2013
    Yucaipa CA
    87
    Look like a standard 300W(maybe) pool light. Make sure the breaker is turned off. Remove the screws to the outer frame and lift the entire unit out of the water onto the deck. There should be enough electrical cable coiled behind the assembly to bring it out of the water. Once out of the water you can disassemble the light and check to make sure the light fixture is still ok. Before reassembly make sure the inside is dry and rust free and turns on properly. Don't run it very long outside of the water as it can damage the fixture from overheating(Don't ask me how i know). Any pool supply place should have or be able to get the replacement lens for you, in either glass or plastic.
    skeeter
    47 yr old(1977) 18,000gal Kidney shaped 38ft long plaster Pool with built-in Spa, Pentair Intelliflo VS3050 Pump, Pentair 48sf DE filter, Raypack RP2100 gas heater. HTH 5-way test kit
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    651
    Make sure and buy a new gasket to seal the replacement lens. Follow the instructions included with the replacement bulb on proper sealing.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Oct 2011
    Minnesota
    164
    I would guess it was damaged from freezing. A lot of people remove the light and wrap it in a towel and keep it on the pool deck during pool winterization.
    20x44 IG vinyl. Intelliflo, Pentair Cartridge Filter (420ft^2), Raypac 336K, Kreepy Krauly
    Pocatello, ID
    29
    Quote Originally Posted by elwood58
    Thank you for the tip. Amazon has a ton of pool light gaskets. Any idea which one this light uses by the look?
    ps0303's Avatar
    Jul 2011
    FL
    3,681
    Turn the breaker for the light off, pull the light out of the niche, remove the retainer ring around housing, and then remove the gasket and measure it. You should also be able to find, hopefully, a sticker on the housing telling you want brand/model of light it is. This will help you find the right gasket. Are their any pool stores near you? If so, might be easier to get what you need from them instead of amazon and then waiting on shipping.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Pocatello, ID
    29
    Quote Originally Posted by jmhjgh
    Sounds like a great guess -- it got very cold last winter. I had no idea one could remove the light and put it up on the deck. Thanks for that tip, too!
    Is it a bad idea to remove the light and let it sit near the bottom of the pool? I can't imagine that it would freeze 8ft down (6.5ft when partly drained for winter).
    Pocatello, ID
    29
    I ended up getting a Pentair Intellibrite 5G LED color light. The current light seems to be a Pentair, based on the pattern along the ring just outside the broken glass.
    I'll post photos of the replacement process for those on this forum that have a similar problem (I suspect replacement will be the same even if using a standard replacement light).
