Results 1 to 10 of 10
Thread: Need advice
    Apr 2013
    South California
    69
    Need advice
    Just received Taylor k2006 kit. This is numbers:
    FC = 0.4
    CC = 0.4
    PH = 7.8
    TA = 90
    CYA = 0 ??? because even the tube is filled, I can still see the dot.
    SWG - 3200
    Chlorine is very low. CYA is also low. PH is bit high.
    Summer Escape 4k gal-AG
    Intex sand filter 1600 GPH
    Intex SWG model 54601
    Taylor K2006 kit & Taylor Salt Water Test Kit K-1766
    Installed 4/29/13
    Re: Need advice
    Yes, your CYA is zero.
    You need to raise your CYA level. With CYA near zero you lose chlorine to sunlight as rapidly as it can be added to the pool.
    The recommended CYA level for use with a SWG is between 70 and 80. But don't go all the way up to there in one step. It is too easy to overshoot your target level. Remember it is easy to add more CYA, but really difficult to lower it if you add too much.
    Apr 2013
    South California
    69
    Re: Need advice
    Based on pool cal, I need to add 37 oz of CYA. Should I need add less than that at first?
    And how about PH, TA, and CC? What do i need to do at this point?
    Installed 4/29/13
    Nov 2010
    South Central Kentucky
    283
    Re: Need advice
    what does the water look like? is it clear?
    I say this, because if not, you need to shock the pool first. And, if shocking is necessary, you don't want your CYA up at 70 just yet. You can shock at that level, but it's quite a bit more costly to do so.
    Just to prevent further questions, if you do need to shock, bring the CYA level up to a calculated 30 (it won't show on the test for a while so just trust it's 30) by putting the correct amount. For your 4k gallon pool that would be 16oz by weight or 17oz by volume (dissolved in a sock hanging in front of a return is how I prefer). Then bring your FC level up to 13 by adding 105 oz of bleach and then keep it there by monitoring at least every hour or so until you meet the following 3 conditions.
    The water looks clear
    you pass the overnight drop test (drops less than 1 point overnight on the FC test)
    CC is less than 1
    After this, let the levels fall to normal and enjoy.
    You can address the pH with muratic acid. That's what many here use. Be careful and read up on the use of that chemical before attempting. Not trying to scare you, but bad things can happen if handled improperly. 10 oz of 20* Baume muratic acid will drop the level from 7.8 to 7.2 in your pool.
    15x32 vinyl liner, 14,400 gal, 1.4hp Centurion pump, 3/4 hp booster pump, Hayward Pro Series S244T Sand Filter, Hayward H200 heater (digital readout)
    Aqua Rite Electronic Chlorine Generator, Hayward Phantom cleaner, TF 100 test kit
    Pool School, Pool Calculator
    Apr 2013
    South California
    69
    Re: Need advice
    Yes, it's crystal clear.
    Installed 4/29/13
    38,290
    Re: Need advice
    Add the CYA. Watch the pH, get the FC back up. Ideally CC is 0 and the FC will take care of that.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Apr 2013
    South California
    69
    Re: Need advice
    Got it. Thanks
    Installed 4/29/13
    Nov 2010
    283
    Re: Need advice
    guess I should have waited a minute to see if you responded before going back and editing all of that extra info in...
    Apr 2013
    South California
    69
    Re: Need advice
    I added about 1.5 lbs (24 oz)of CYA last night. Put it in the sock and hang over the return. It was almost dissolved in the morning. Now it's gone. I am going to let the pump runs few hours after that.
    Can I test the cya later today? The reagent is not much. Three times test, probably.
    Installed 4/29/13
    38,290
    Re: Need advice
    Wait a week to test. Assume it is at the level you were dosing for to determine your required FC level.
