Thread: Sta-Rite SD110
    Sta-Rite SD110
    Hey Gang,
    I have a Sta-Rite SD110 filter for my gunite inground pool. I think it was put in around 2004, so just under 10 years ago. I don't believe the filter grid elements have ever been replaced. They are yellow, but otherwise appear to be holding together. How will I know these things need replacement? I see they are quite expensive, so I don't want to replace them unnecessarily.
    Thanks!
    20,000 Gallon Gunite IG Pool w/ AG attached Spa -- Built 2004
    Sta-rite S8D110 DE 106 GPM Filter
    Sta-rite Max-E Pro 3 HP Pump
    Hayward H300 Electric Pool Heater
    Polaris 380 Cleaner
    38,290
    Re: Sta-Rite SD110
    If you start seeing dirt passing back into the pool or if your pool will not stay clean, that would point to a problem with the cartridge. Just do a thorough inspection to look for damage or tears. Antother problem would be a build up of calcium cloggin it up.
    Please add your pool details and location as described HERE as it will help us help you.
