Results 1 to 11 of 11
Thread: Opened pool, pump not starting
    Jun 2011
    Central NJ
    12
    Hi All, opened the pool this weekend, when I turned on the pump there was no movement or turning that i could tell, and i heard a very faint buzzing sound for about 10-20 seconds which then stopped by itself. Trying to turn on or off again didn't do anything, no buzzing either. I am completely new to pumps in general. Any ideas/suggestions on what to do?
    The pump is a Hayward 1HP pump, must be at least 4-5+ years old and has had no issues at all the last 3 years that I have used it. It is exposed to the elements outside (under a tree/large bush though), but is raised on a pad and definitely hasn't flooded, etc.
    Thanks in advance
    16.5 x 32.5 Vinyl lined IG (16,000 gal) oval shape, 3ft to 6ft deep, 1 HP pump (12-14 PSI) 4-6 hrs/day, Hayward Pro series High Rate Sand Filter S244S, Hayward CL220 Chlorine feeder (I have stopped trichlor tabs and switched to Bleach!), 1 bottom drain and 1 skimmer in, 2 returns.
    Jun 2011
    Central NJ
    12
    Re: Opened pool, pump not starting
    Ah, was reading the Hydraulics 101 sticky post and found this -
    Pump motor will not start:
    Shaft turns manually but motor hums and will not turn - Bad start capacitor, replace capacitor
    Shaft is frozen and motor trips breaker - Frozen motor bearings, replace motor
    Will have to try that....
    Jun 2011
    Central NJ
    12
    Found a good video - Pool Pump Capacitor Test and Repair http://www.youtube.com/watch?v=k-cVgpz7GYQ
    Sounds like it could be it.... will try it. Thanks mas985 and thanks youtube!
    Jun 2011
    Central NJ
    12
    So i followed the video and took out the capacitor, but when i tested it with an OHM meter as shown in the video it tests ok, the OHM meter registers a spike in the reading.... so it seems like the capacitor may be good... not sure what to check/test next. any suggestions welcome. thanks!
    Jul 2010
    Central, New Jersey
    31
    Can you spin the shaft by hand?
    If you can't spin the shaft, then it might be a frozen bearing. You could try freeing up the shaft with a wrench on the back end of the motor. Then once it spins, reconnect and see if it starts on it's own
    Where you located in Jersey? I'm in central jersey as well.
    Pool: 20 X 40 Rec - 28,500 gallons;
    Type: IG with Vinyl Liner
    Filter: Hayward 46SqFt DE Filter
    Pump Size: Hayward Super-Pump 1 hp
    Also check the centrifugal switch on the back side of the motor. When the motor gets to a certain speed the weight opens the start circuit and switches to the run circuit. My switch had gotten a little rusty and stuck in the "run" mode. A little WD-40 fixed it right up.
    16x32 Oval In-ground Vinyl, ~17,000 gallons, Hayward 1hp Superpump, Hayward S245T Sand Filter
    Worn out sand? sand-filter-expert-help-t30049.html
    Drain the easy way: cyanuric-acid-blues-draining-pool-t43843.html
    http://tftestkits.net/splash-page.html , pool-school/chlorine_cya_chart_shock , pool-school/shocking_your_pool
    Here's a link to another thread with pictures. hayward-pump-problems-trouble-starting-t51940.html
    Jun 2011
    Central NJ
    12
    CyclingCraig and macgulley thanks for the advice! (and great link to that thread too), will try those later today, didn't get a chance yesterday.
    Oh, i'm in Edison btw....
    Jun 2011
    Central NJ
    12
    Good news, the pump is working fine. So it turns out that the shaft was frozen up (thanks cyclingcraig!!) Grabbed it with some pliers and gave it a tug to break it free and then it spun freely, so I put everything back together and viola, the pump started up just fine! Tested it on and off a few times and seems ok
    Thanks for all the help, this forum is great and you guys are all awesome. A friend just moved into a new house with a pool and I told him that THIS is the place to learn all the right things about the pool
    Jun 2011
    Central NJ
    12
    Here's a pic of the pump shaft, it took me a few min to find it so hopefully this will help someone else locate it. It's the dark piece behind the centrifugal switch (with the 2 springs), kinda narrow access so had to use needle nose pliers to grab it and turn it.
