Thread: Retaning wall and patio lights!
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Hey all, so i'm trying to figure out what i will do for the retaining wall lights and other lighting options around the new decking. When we did the existing patio and wall i used the Kerr Wall lights (http://www.omnipropittsburgh.com/walllighting.html) and i can say i don't particularly love them, so looking for the options for the new wall that will go around the pool.
    So folks please post up some pictures/suggestions of your lighting setups.
    19200gl rectangular gunite/diamondbrite perl pool || Coverpools auto cover || Jandy variable speed 2hp e-pump & Polaris PB4-60 booster pump || Polaris 3900 sport cleaner || Jandy CV filter || Jandy AqualinkRS8 w/Aqualink touch || Jandy iAqualink2.0 || Jandy Watercolors LED || Jandy AquaPure 1400 SWCG || Hayward auto chlorinator (backup) || Raypak 117k BTU heat pump
    Re: Retaning wall and patio lights!
    Curious if you have come across these: http://www.elementalled.com/catalogsear ... r+&x=0&y=0.
    We, too, have a retaining wall. There is a walkway / large patio area. But, 1/2 of the pool has a retaining wall (which is at a seated height). I've been thinking about using the waterproof light bars. Not sure if you had seen them yet. I am going to order a few and see what they are like. When I get them up -- I'll post some pictures.
    I had never heard about them before, but stumbled across them and just thought they were very cool (with lots of options -- color -- dimming).
    Good luck!
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Yea I've seen these led strips, they're pretty good.
    I'm actually thinking about putting a rope light under the cap for the entire length of the retaining wall. Just can't figure out what to use for clips since the typical plastic clips won't work with the stone retaining wall...
