Results 1 to 7 of 7
Thread: "Crystals" floating on water surface -- any thoughts?
    New pool owner; specs in signature. Opened it a few weeks ago and have been balancing the water since. Cleaned my filter Saturday morning; added some synthetic DE after getting it running again. The water is absolutely crystal clear and chemicals appear to be balanced, but in the morning (when pump is off) the surface of the pool is covered with these "crystal" like particles. I scooped one up in my hand and it sort of just disintegrated. Here's a photo:
    [attachment=0:2f0hnb21]pool crystals.jpg[/attachment:2f0hnb21]
    Any thoughts what this is, and how to get rid of it?
    15K, IG Fiberglass, Pentair Cartridge, Nature2 Fusion, 2x PoolCleaner, installed Fall 2012
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: "Crystals" floating on water surface -- any thoughts?
    Can't really see...but I can imagine a fluffy seed (like a dandelion or cottonwood) looking a little like a crystal if it sits on the water surface. You sure it's not something like that?
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    My guess would be pollen, too. Where are you located? I live in northern Virgnia and I have a lot of pollen on the surface of my pool right now.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Quote Originally Posted by kcindc
    Pollen makes sense. I'm in Durham, NC. Seems like such a silly and simple answer -- thx!
    Jul 2009
    Long Island, NY
    267
    I agree also. Lot's of pollen in New York this weekend.
    Free-form concrete walls with vinyl liner, 18,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter (using cellulose media), Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system.
    Nov 2010
    South Central Kentucky
    283
    yep, same thing here in South Central KY. I run the net across the surface for a bit to clear what I can and let the skimmer do the rest. Hard to keep up with early in the season though.
    15x32 vinyl liner, 14,400 gal, 1.4hp Centurion pump, 3/4 hp booster pump, Hayward Pro Series S244T Sand Filter, Hayward H200 heater (digital readout)
    Aqua Rite Electronic Chlorine Generator, Hayward Phantom cleaner, TF 100 test kit
    Pool School, Pool Calculator
    Just thought I'd follow up to end the thread. Definitely pollen; skimmer taking care of it. Thanks for the comments from everyone; being a new pool owner I'm paranoid about maintaining water quality!
