Thread: BBB for Beginners
    BBB for Beginners
    Greetings, new member, first time post!
    I found your site while searching for ways to clear my algae ridden pool. We just bought a mess cover at the end of the last season, and I pulled it back to see how the water was yesterday and found a mess that I'm going to have to clean up. Through all my searching, I ended up here and am impressed with what I see already. Can't believe I didn't find you before now!
    Just purchased the TF100 test kit, because it's about time I start balancing my pool correctly and using the right tools.
    I have a question. I just read about the BBB method and I would like to start using it, although I have an inline chlorinator which I'm used to putting 3" tabs into. Since I won't be using tabs anymore, do I just leave the chlorinator turned off?
    20K gal, vinyl, 1 1/2 Hayward SuperPump, Hayward Perflex DE Filter (EC-65 or EC-75), In-Line Chlorinator, Kreepy Krauly
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: BBB for Beginners
    I leave my chlorinator turned off. You can used it for vacations or if you need to raise your CYA.
    Mar 2007
    San Rafael, CA USA
    12,082
    Welcome to TFP!
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    my 3rd season using BBB and just opened the pool to nice clear water. BBB is a simple and effective method to manage pool water quality - it just works!
