Thread: Help Green Pool Pump not working
    I have a new Speck pump. I have filled both baskets with water cleaned the filter and still pump not working. I am new to taking care of pool so very little knowledge. Please help!
    30,432
    Re: Help Green Pool Pump not working
    My assumption is that the pump powers up and spins but produces no flow...does the pump basket fill with water completely or does it have bubbles in it?
    It does not fill up with water, I have filled both buckets with water and there is no flow
    30,432
    You have a suction side air leak. Somewhere between the pump and the skimmer(s), air is being sucked into the system. Find that leak and your issues will be solved.
    Mr. Blue's Avatar
    May 2013
    Spring, TX (Houston)
    95
    I had a similar issue. I found out that when I emptied out the pump basket, some debris had fallen and somehow gotten into the impeller (I had been vacuuming some pretty hairy stuff). The pump would run and pull some water, but the pump basket would never fill with water. I cleared out the impeller, using a wet vac on blower mode, and the pump started working fine again.
    I went and picked up a Skim Vac immediately following this incident.
    23K Gallon Freeform Tile Inground
    Hayward Super II 1.5 HP -- Pentair FNSP48 DE Filter @ 120 GPM
    Polaris 3900 Sport (with Booster Pump)
    Pool School Attendee -- The TF-100 Test Kit and the Pool Calculator keep my pool Trouble Free -- BBB Supporter
