Results 1 to 7 of 7
Thread: Intex SWG problem
    Apr 2009
    Lakin Ks
    33
    Intex SWG problem
    I have a low salt warning. I put in the same amount of salt as I have in past years, the cell is clean. I even tried a different cell. What else could be causing the problem. I'd also like the option to run the pump longer while not running the SWG. What about running the cell on a second powersupply on it's own timer?
    5,000 gal above ground pool summer escapes pool
    Feb 2008
    Denton, TX
    5,061
    Re: Intex SWG problem
    Have you tested your salt level? If so, what is it?
    Apr 2009
    Lakin Ks
    33
    I have not tested the salt level. I just add the recomended mount of salt as I have in years past. I'll have to get something to test, what do you recomend? Also How can I run the pump longer without running the SWG? Keep in mind this an intex all in one settup. Thanks!
    Feb 2013
    Yukon, Oklahoma
    220
    Taylor makes a very nice salt testing kit for around 15-20 bucks as I recall. You absolutely must test your level. Until you do, you won't have a certified answer. Aslo, how did you add the salt? Did you disolve it in a bucket first, or did you just dump it in the pool?
    Your SWG is only "running" for as long as you program it to. Mine runs for about an hour a day. Read your instruction manual and you will see you need to keep the power on it 24/7 so it retains it's memory. So you program it to come on at 8am everyday, and every day at 8am it will come on, do it's thing, then turn off ALTHOUGH the led lights may be illuminated and I believe the "sleep" indicator light will be on. Run the pump as much as you want.....
    Bob E.
    Apr 2009
    Lakin Ks
    33
    Thanks for the advice on the salt test bob! I'd like to run the pump longer because where I live it is windy and dry, so I always get dirt and leaves in the pool.With the intex saltwater system it has the pump,filter and SWG all in one unit.You cannot run the pump at seperate times than tha SWG. I'de like to add a 12Vdc or 24VDC power supply on a timer so I can run the pump continuously and run the SWG only when needed.
    Quote Originally Posted by gayler
    I would also recommend getting salt level test. If the salt level gets too high, you will burn out the transformer in the intex SWG and render it useless. Every time I have had the low salt warning on mine its been because the cell isn't clean. It may LOOK clean but its not. Fill it with vinegar and let it it for 24 hours. If that doesn't do it you might have harder mineral buildup and you'll need a product specifically designed to remove mineral deposits (get this at a hardware store.)
    It might also be that the water's too cold. Anything below 55F and mine reads low salt with 3000ppm water.
    Intex 16 x 48 Ultra Frame AG
    Intex SWG
    Intex Skimmer
    Columbia 50lb Sand Filter w/ US Motor Pump
