Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: 4 hard days...worth it.
    Mr. Blue's Avatar
    May 2013
    Spring, TX (Houston)
    95
    Hey everyone,
    I recently took on the task of turning my mother-in-laws swamp into a pool and thought I would share. Stabilizer, algicide, acid, shock, shock, shock, shock, and removing the ridiculous piles of algae was the key. I ended up filling about 6 large contractors bags full of algae in the process.
    I lurked here for a few days, and learned a lot from the threads I read through.
    Cleaned the filter before and after, and was backwashing about every 6 hours.
    Now to start on the landscaping and rest of the backyard.
    Thanks for the help!
    23K Gallon Freeform Tile Inground
    Hayward Super II 1.5 HP -- Pentair FNSP48 DE Filter @ 120 GPM
    Polaris 3900 Sport (with Booster Pump)
    Pool School Attendee -- The TF-100 Test Kit and the Pool Calculator keep my pool Trouble Free -- BBB Supporter
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    Re: 4 hard days...worth it.
    Well done.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Mr. Blue:
    Great job What a turnaround in a short time.
    Stabilizer, algicide,...
    Going forward, I would use only liquid bleach as the chlorine source and dose according the the Chlorine/CYA chart (see link in my sig). That alone will prevent another algae infestation. Algaecides are completely unnecessary and some (in particular the copper-based algaecides) can do more harm than good with prolonged use by causing metal staining.
    Mr. Blue's Avatar
    May 2013
    95
    Quote Originally Posted by BoDarville
    Mr. Blue:
    Thanks!
    Yeah, I've been looking into the BBB method. I have little experience with pools (until now), so I had to rely on my local pool store for help with this task.
    At the moment, the only thing in the pool (chemical wise) is the chlorine floater. I tested the water last night (and took it to the pool store for a second opinion) and all the levels are good now.
    Now I just need the water to warm up a bit!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,643
    That oughta be worth a few brownie points!
    Mr. Blue's Avatar
    May 2013
    95
    Started taking the ugly rocks off today. Here's an updated photo.
    [attachment=0joels3y]ImageUploadedByTapatalk 21370105935.866253.jpg[/attachmentjoels3y]
    Next, we're going to retile the top 9 inches inside the pool and figure out what we want to do with the trim around the pool.
    I'll keep updating with photos.
    Guest
    Looks so much better without those rocks around the edge. Great job !
    May 2013
    New Jersey
    64
    Wow! That is inspiring! Thanks for sharing the pics!
    Bernie
    20,000 Gallon (16 x 32), IN ground, Vinyl Pool
    Hayward Single Speed 1-1/5 Hp Pump - 3/4 HP "Booster" (?) Polaris 280 Vacuum
    48 Sq Ft, 96 GPM, Diatomaceous Earth Filter
    Pool is approximately 15+ years old- Newer than 1985
    Hayward 300,000 BTU H300MV Heater (Milli-Volt UGH!!)
    Mr. Blue's Avatar
    May 2013
    95
    Thanks!
    We got the gross mustard colored tiles off. Now getting ready to retile.
    [attachment=0:1u1p8jtt]ImageUploadedByTapatalk 21370126999.088872.jpg[/attachment:1u1p8jtt]
    May 2013
    New Jersey
    64
    Now- now seeing on a bigger screen- that is truly impressive! And a lovely shaped pool by the way. I do love the "lagoon" style pools. I guess they are more expensive to design or install? But I know a lot of the big rectangles like mine were built 30 years ago.
    Beautiful job!
    Bernie
    Bernie
    Mr. Blue's Avatar
    May 2013
    95
    I'm not sure. This pool is over 40 years old, so I have no idea what the cost was to build it.
    Casey's Avatar
    SW PA
    10,457
    So glad to see those rocks removed! It looks so much better without them!
    Mr. Blue's Avatar
    May 2013
    95
    Thanks. The tile finally came in today, so hopefully I'll be starting on that in the morning.
    May 2008
    Long Island, N.Y.
    16
    Looks 100X better without the rocks. Probably a little safer too..seems like the rocks stuck up a little, and were a tripping hazard.
    Mr. Blue's Avatar
    May 2013
    95
    Update.
    Got the new "tile" in over the weekend. Had a little trouble cutting the glass, but it's ok for now. We also filled in some of the cracked concrete.
    Next, we will lay travertine around the edge. That is the plan, anyway. Also looking into a spray deck...so we may even out the glass and go all the way to the pool. Still exploring options there.
    [attachment=1:1mand6mn]ImageUploadedByTapatalk 21371472662.075411.jpg[/attachment:1mand6mn]
    [attachment=0:1mand6mn]ImageUploadedByTapatalk 21371472677.859338.jpg[/attachment:1mand6mn]
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Jun 2013
    Huffman Tx
    190
    nice work
    alanpaul's Avatar
    Aug 2010
    South Florida
    227
    Beautiful improvements.
    Alan in Wellington, FL - near West Palm Beach
    15,200 gal IG, painted plaster, 1988; 200 SqFt cartridge filter, 2013; 1.5 HP 1-speed pump (uprated), 2005; heat pump, 2005;
    soon to repair (dead) SWG AquaRite T-15 cell, 2005, and replace (dead) suction-side cleaner, 2005.
    Almost everything died this winter 2012-'13, and I know we shouldn't complain... but, Arrgh!
    MiaOKC's Avatar
    Apr 2012
    Oklahoma City, OK
    347
    I love the tile you chose for the waterline! Are you a DIY-er or professional tile person? I've been wondering about re-doing our waterline tile ourselves and having someone come replaster our pool for us, but haven't gotten the guts worked up for it yet.
    35,000 gallon gunite pool, semi-T-shaped, 29x15 shallow end and 16x22 deep end, built in the mid-1970s and renovated 2013-2014 // Polaris 9300 Sport robotic cleaner // Taylor K-2006 ... Learning as we go and so grateful to everyone here for their help! Our reno thread
  20. Back To Top    #20
    Jan 2013
    Houston, TX
    1,079
    Very nice
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
