Thread: Skimmer door got jammed by toys
    My problem is with my Hayward Max-Flow II pump. I have an 15K gallons AGP that does not have a bottom (main) drain, it only has a single skimmer. The problem is that once last year, and then again this past week, the skimmer door got jammed by toys, and there was not enough water getting to the pump to keep it primed, but it kept turning for many hours, heating up the little water it had in the pump strainer house to the point where it became so hot that it heated pieces around so much that they changed shape: the flexible tubing between the pump and the sand filter head twisted and got larger, the strainer basket now has a bump where the water goes to the impeller, and the strainer cover color changed from transparent to solid white.
    I would like your advice on how to avoid this situation to occur again, accepting the basic fact that that toys will again jam the skimmer door in the future. Installing a main drain at this time would not make sense, the pool is only 3 years old. Would there be another way to provide a second water access to the pump for when the skimmer gets jammed? Or could I install a heater sensor to stop the pump if it heats up again?
    I would prefer the second water source approach because I also have solar panels, so stopping the water circulation would not be ideal.
    Thanks in advance for your help.
    AGP 30x15x4, 12K gal, vinyl, single skimer (no bottom drain), Hayward Power-Flo Matrix 1.5hp dual speed, 21" sand filter, 160 sq ft of Enersol solar panels on 2nd story house roof, Hayward PoolCleaner 2-Wheel Suction side, BBB method.
    Feb 2008
    Denton, TX
    5,061
    Re: Skimmer door got jammed by toys
    Welcome to TFP!
    I cannot think of a way to reroute water around a stuck skimmer weir and still allow for skimming action to take place. May just need to be more forceful in the "pick up your toys or lose them" department. I had the same problem with the noodles. Eventually, the noodles were removed and ended up being earned back. Now, the toys get picked up.
    Mar 2013
    Sayville, NY
    53
    Is it possible to add another skimmer? Or maybe put a guard in front of your current skimmer that will not allow it to get jammed? My skimmers don't have doors in them, don't know if that is bad or not, but would it help if you removed the doors?
    16 x 32 Vinyl IGP ~22000 G
    In the end keeping the water level a little higher resolved my problem. I am now keeping the water level at about 1 to 1.5 inch below the top of the skimmer mouth and all has been fine this summer. Thanks for your input.
    May 2009
    Pennsylvania
    99
    A couple of years ago I saw a guard plate at a pool store that snapped into the skimmer opening. It jutted out into the water a few inches with a grill face and provided enough water area around and behind it that no amount of toys or such would do what you described. It appeared to be a real simple an inexpensive fix for your problem. Sorry I can't remember the exact name or mfg. Maybe a google search will turn something up?
    28 foot doughboy AGP, dug out to 5 foot, about 18,000 gallons
    1 1/2 HP pump and 100 lb sand filter
    South Central Pennsylvania
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I tried some of the guards but they keep popping off. They do help.
    -- Guy --
