Thread: Cholorinator check valve failure
    I have a Pentair 300 chlorinator. Check valves keep failing two in the last two weeks. What could be the cause of these failures
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Cholorinator check valve failure
    Welcome to the forum!
    Where is the check valve? Can you post a picture of your pad equipment?
    Mark
