Thread: Cya for the desert
    Apr 2013
    Las Vegas, nv
    11
    Cya for the desert
    Hello,
    I am looking for advice as to how much CYA level folks in VERY hot climates are using. Any Vegas or Phoenix TFP members?
    Damon
    New owner, first pool,30+ yr old plaster/gunite,15k gal. White quartz plaster (NEW 5/5/13!)Hayward tristar variable pump Hayward pro grid D.E. Hayward h heater LED color lights.
    Re: Cya for the desert
    CYA is not really a heat issue, rather it is a sunlight issue. The more sun your pool gets, the more valuable CYA is, up to a point. As it happens, the locations you mentioned are known both for their heat and their sunlight.
    Feb 2008
    Denton, TX
    5,061
    If you are running a SWCG, with which we recommend a CYA of 60 to 80, the higher end of that range is better. Regular pools where a CYA of 30 to 50 is called for, we suggest typically running closer to 45 or 50 in very sunny climates in the desert SW.
    Apr 2013
    Las Vegas, nv
    11
    Thanks!!
    Damon
