Results 1 to 11 of 11
Thread: Slides
    Slides
    Hope this is the correct area...I'm looking to put a slide in the existing in-ground pool. It's 11-12 feet deep so want a large slide. Looking for pics and advice please. I'm in the Phoenix area so builders advice would be good also. Thanks in advance.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: Slides
    Check with your insurance company first. Many will cancel your insurance for having a slide or diving board. Good luck.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Re: Slides
    Thanks for the heads up. We already have a diving board and both are very common here in AZ so I think it's just something the insurance companies have learned to deal with.
    Re: Slides
    Hello , I like to get a slide for an above ground pool, I am going to install it on a deck but I cant seem to find one. Can any one help?
    18x36 Ingound vinyl Liner
    25000 gallons
    Jandy Stealth 2 speed pump
    Jandy 340 Cartridge Filter
    Jandy AE-TI 2500T Heat Pump 118000k btu
    Intermatic PE153 Digital
    38,394
    Re: Slides
    Quote Originally Posted by LCjr
    Have you Googled "pool slide"?
    There are a few threads in the forum of people adding slides to their above ground pool ... some just used playground slides with a hose.
    Re: Slides
    I did but I found slides that where up to 1,300.00 a little to much for a slide. I will check a gain thank you.
    25000 gallons
    38,394
    Re: Slides
    That price sounds on the low-side for a pool slide ... they are not cheap. Thus the DIY that a few people have done with playground equipment ... not that I or the forum endorses such things
    Re: Slides
    Yes I agree they are more than what I expected. I went to Toys R Us and they have some but my issue is that they are to narrow. I will keep searching thank you.
    25000 gallons
    Re: Slides
    P.S. Great help
    25000 gallons
    38,394
    Re: Slides
    It is a nice one, I was trying to read the name on the slide but is to small.
    25000 gallons
