Thread: Raising CYA
    Raising CYA
    Hi to all;
    I know I've seen this question before but I was unable to find it on the site:
    Wanting to raise my CYA level about 10 ppm using trichlor pucks. How fast will they raise the CYA level from 20 to 30 ppm?
    Gary R.
    18 X 32 Oval Inground Gunite Pool 20,000 Gallons Epoxy Painted in 2012
    Tagelus Sand Filter TA 60 D/TA 60-Hayward Super Pumps 1 H.P.
    Ray-Pac Heater 266,000 BTU, KLeen Machine Pool Cleaner
    Solar Cover-Rocky's Pool Cover Reel-Intermatic T104R Timer
    TF-100 Test Kit-PoolSkim Skimmer
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Re: Raising CYA
    That completely depends on how much chlorine you actually need to use to keep your pool up. http://www.poolcalculator.com/ enter your pool's capacity in and go to the bottom calculator and see how much trichlor your need to raise your CYA to 30.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: Raising CYA
    Go to poolcalculator.com. Below the calculations table is a section on effects of adding chemicals. Select Trichlor in the drop down box and adjust to dose size. It will tell you based on the pool details you entered in the calculation table.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Re: Raising CYA
    Thanks to all!!!!!!!!!!!!!
    Gary R.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Raising CYA
    For every 10 ppm Free Chlorine (FC) added by Trichlor, it also increases Cyanuric Acid (CYA) by 6.1 ppm. So if your daily chlorine usage is around 2 ppm FC per day, then to add 20 ppm CYA it will take 20/0.61/2 = 16 days. The formula is Days = (desired CYA increase) / 0.61 / (FC usage per day)
