Thread: Pentair Booster Pump Drain Plug
    I broke the plastic drain plug for my booster pump. i was going to temporatily fix with a brass or stainless bolt. Does anyone know what size it is. It looks like 5/16.
    Jeremiah Hough
    22,000 gallon, vinyl liner, chlorine, with auto cover
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Pentair Booster Pump Drain Plug
    Drain plugs are usually 1/4" but the manual should have a part number so you can order one.
    Mark
