Thread: Valves everywhere! Do this look right to you?
    Hi again, newbie pool owner from Dallas here. I have a pool / spa combo, and I haven't had time to talk with a pool guy at the house yet. I see 4 vales coming into the pump, so I'm guessing these are:
    1) main drain
    2) skimmer 1
    3) skimmer 2
    4) spa drain
    They aren't labeled, but one is off to the left by itself. I'm guess that's the spa drain, correct? It is currently off, and the other three are on. Is that how it should be usually? My spa is just overflowing into the pool.
    Thanks!
    Tyson
    25G IG Plaster, DE Filter
    Feb 2008
    Denton, TX
    5,061
    Re: Valves everywhere! Do this look right to you?
    Hard to tell which is which. You're probably going to have to isolate them one at a time to find out where they go and then get out your label maker.
