Thread: Converting to Chlorine
    I have a 18 x 33 x 4 1/2 ft pool. I want to convert to Chlorine from Namco's version of Baquicil. How should I start? I am also going from a sand filter to a Hayward cartridge filter. Should I install the filter first or try and clear the water? I would like to avoid
    emptying and refilling the pool if possible.
    Joseph L Delia
    Mar 2008
    Central VA
    328
    We'll let the longtime members answer you, but my understanding is that you want to convert first, then change any filter media (or filter in this case) after the conversion.
    Todd
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    http://www.poolcalculator.com/
    First, adjust your PH to between 7.2 and 7.4, get a test kit that has the FAS-DPD chlorine test (such as the TF Test Kit or Taylor K-2006), and stock up on bleach.
    The conversion proceeds by adding enough bleach to bring the pool up to 15 ppm, wait an hour or more, and repeat. Continue to do this as frequently as practical until your FC level stays the same overnight.
    After the FC level holds overnight you replace the filter and then add CYA.
    Keep in mind that the pool will turn all kinds of strange colors during the conversion.
