Thread: Medium Grade Vermiculite?
    Hello all,
    New to the fourm and currently getting my head around my DIY IG pool......(pool should arrive this week)
    Looking for some advice on the mix for the bottom. First of all, is the vermiculite for pools the same vermiculite used in gardening?
    And, I found a local source for vermiculite, but it's a medium grade versus fine. Will a medium grade work?
    Thanks for the input,
    TH
    18 x 36, 2' Radius Corners, Steel Walls......DIY Construction started May 2103.
    Feb 2012
    Maryland
    400
    Re: Medium Grade Vermiculite?
    Quote Originally Posted by strmh
    Hello all,
    TH
    Medium grade vermiculite is what you want. Yes, the vermiculite for gardens is the same as is used for pool bottoms. You mix a bag of the vermiculite, half bag of portland cement and ~10-12 gallons of water for one batch (note, these instructions are estimates from advice ive seen here).
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    Thanks for the quick reply.
