Thread: Liquid Chlorine
    Is Liquid Chlorine (Sodium Hypoclorite 12.5%) the same as 2x bleach?
    25k Gallon Gunite Inground Pool
    Pentair FNS PLUS DE filter
    Pentair WhisperFlo WF-24 (seems like single speed)
    Bel Air, MD 21015
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Liquid Chlorine
    Liquid chlorine and bleach are both sodium hypochlorite, just different strengths.
    You're done SLAMing when:
    Feb 2008
    Denton, TX
    5,061
    Re: Liquid Chlorine
    With regular old bleach typically being 6%, the 12.5% is essentially "double strength".
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Liquid Chlorine
    ^ What they said.
    One thing to be aware of with the higher concentrations: They degrade faster than do the lower concentrations, especially when stored in a warm-hot location such as a garage or shed. When purchasing the higher concentrations (>= 10%), it is best to purchase from a source where the product turnover is reasonably high.
