Thread: valve actuator cable length
    Thinking of cleaning up my valve actuator cabling, do any installers ever shorten these cables and recrimp the plugs rather than leaving all of the extra cable rolled up? It would sure clean up the install.
    LB
    Sunny Sarasota Fl area
    10K Pool/SPA, Pentair equipment
    IntellifloXF
    Easytouch upgrade Panel
    Intelliclor IC-40
    Techno-Solis Solar Panels
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: valve actuator cable length
    If you have the skills, I don't see anything wrong with it, however you might want to leave just a little extra in case of future plumbing changes, etc. The extra on mine is stuffed into my solar control box, there was plenty of free space in there, and it is fairly small cable.
    Ike
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Installers usually never shorten the cables. They find an out of the way place to coil and wire tie them up. If you cut them you leave yourself open to possible problems down the road so why risk it.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jan 2012
    340
    Just pull it up in your automation box and roll/zip tie it up nice
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    Thanks everyone, I actually had to pull it out of the box because it was binding with the wiring of the new panel.
    LB
    IntellifloXF
    Intelliclor IC-40
