Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Testing Help?
    Testing Help?
    It's too cold to swim yet, but we are new pool owners (new pool completed last fall) so we are trying to learn early while we can.
    Here's the results I got from the Taylor 2006 test kit:
    Free CL - .5
    Comb CL - .5
    PH - 7.4
    Total Alk - 50
    Calc Hardness - 130
    Cyanuric acid - 0?
    According to our Intellichlor our salt levels are around 3350, which is supposed to be ok for our pool. I don't understand how our chlorine levels could be at .5 if the salt is ok? We did shock it about three weeks ago when we opened it and no algae for the last two weeks.
    On the cyanuric acid, I filled the little bottle to the 7 line, then added the reagent or whatever until it was at 14. I shook it for 30 seconds. It was not cloudy in the least.
    I double checked both of these tests to make sure I wasn't doing something wrong.
    Thoughts?
    Chesterfield, MO
    In Ground vinyl liner pool
    - Lagoon Shape - 40'x30'x20'
    - Intelliflo VS Pump
    - Intellichlor Salt System
    - Triton II Sand Filter
    - Pentair MasterTemp Heater
    - EZ Touch Controller
    - Faux stone water feature with sheer descents
    - Turbo twister slide
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Testing Help?
    Was Cyanuric Acid added at fillup last fall? The FC is .5 because there is no CYA in the pool and the sun is destroying all the FC.
    Re: Testing Help?
    No, we didn't realize we needed to add it. Wow, ok. So once we add the cyanuric acid the chlorine will level out? Any idea how much we need to add?
    Chesterfield, MO
    30,432
    Re: Testing Help?
    Check out the pool calculator link in my sig. It will perform all the dosage calculations for you.
    Re: Testing Help?
    So I put in my results in the pool calculator. I'm kind of guessing on our pool gallons, but I think I'm relatively close at 27k gallons.
    It says we need 252 oz. solid or 650 oz. liquid. Does that seem right? I don't even know how I would go about putting that in in solid form - it's 16 pounds. Seems like it would take a month to dissolve that much.
    Chesterfield, MO
    30,432
    Re: Testing Help?
    The calculation seems correct assuming your pool is 27k. Purchase that much CYA and then add (slowly) about 144 oz to your skimmer. That should get you to 40 ppm and then you can add the rest in 4-5 days.
    Add only 144 oz because you DO NOT want to overshoot your target. Give the CYA 4-5 days to dissolve and register on the CYA test and then test. If it's right at 40 ppm, you have dosed correctly and then can add the rest.
    Re: Testing Help?
    Thank you!!
    Chesterfield, MO
    11,969
    Re: Testing Help?
    If your water is clear - you are not shocking, etc and see no reason you will need to clean your filter - you can pour the CYA directly into the skimmer and allow it to dissolve in your filter. The filter must run for nonstop for 48 hours or so while it dissolves - but don't bother testing for 5 days or so. If you need to clean the filter a lot might be lost which is why we recommend the "sock method". I would purchase online - search for the best price since you are buying such a quantity.
    Re: Testing Help?
    OK, so I tested this morning and FC is looking better. I know it's a little early for the CYA, but I went ahead and posted the current reading. We are still dissolving the 10 or so pounds that we started with.
    Free CL - 6
    Comb CL - 0
    PH - 7.0
    Total Alk - 50
    Cyanuric acid - 33
    Now my question is, what should we do about the PH and Total Alk?
    If I input the 7.6 PH and the 70 Total Alk targets, it tells me to:
    Add 59 oz. of washing soda
    Add 127 oz. of baking soda
    I believe adding the product to correct one can impact the other, so I don't really want to add both products do I?
    Chesterfield, MO
    Feb 2013
    Metro St. Louis
    93
    Re: Testing Help?
    Hi Bfassler! We are not far behind you...as the PB is finishing up the next few days. Good luck on getting your numbers in range...I will be referring to your posts as we start adjusting soon
    Paul
    Sterling Steel IGP lagoon 21' x 35' w/6' deep end, Pentair 5g LED lights (x2), Pentair Landscape LED light, Pentiar IntelliFlo VS pump, Pentair 420 Cartridge filter, Pentair IC20, 4 gas Tiki Torches, LoopLoc Ultra Loc II, Deck Jets(x3), Raised Planter Bed with 3 Pentair bronze sheer decents, AquaBot Breeze 4WD, Pentair Legend II
    Re: Testing Help?
    Paul - feel free to message me, I can let you know what I've learned. Where are you pictures???????
    Chesterfield, MO
    Feb 2013
    Metro St. Louis
    93
    Re: Testing Help?
    We have not posted pics in a few weeks...it has been so hectic...but I will post some soon. We have been doing the non-pool stuff ourselves...and it has been lots of work! We had 9 tons of rock delivered last week, and I have been shoveling it since. Should be done tonight, liner in Sat, and fence in next week. I will message you
    Paul
    DCAG's Avatar
    Jul 2009
    Merrimack, NH
    95
    Re: Testing Help?
    Quote Originally Posted by Bfassler
    Don't worry about your pH. It will go up on it's own because of the salt system. Just put in the baking soda.
    Dan
    16' X 24' Wilkes Pools "Genesis", 10K Gal
    Hayward Powerflo Matrix 1 hp, & 18" Pro Series sand (S180T)
    Re: Testing Help?
    Thank you. One more question - the FC is a little high. Should I set my Intellichlor down to 0 until it goes down? Or just lower my Intellichlor setting from 65% to something lower?
    Chesterfield, MO
    DCAG's Avatar
    Jul 2009
    Merrimack, NH
    95
    Re: Testing Help?
    Don't turn it off, just keep lowering it until you get find a setting that keeps you at the level you want.
    Dan
    Re: Testing Help?
    Latest test results:
    Free CL - 4.5
    Comb CL - 0
    PH - 7.0
    Total Alk - between 60 and 70
    Cyanuric acid - around 55
    This is after adding about 8 pounds of baking soda and continuing to add the cyanuric acid over time.
    My PH was up around 7.4 and TA up to 70, but both are now trending down again.
    I can add a bit more baking soda or washing soda/soda ash based on the pool calculator; still not sure about the impact of the PH on the TA and vice versa. I didn't notice my PH to go up a ton when I added the baking soda.
    Please let me know your thoughts on raising PH. Also, what IS washing soda? I see some kind of Arm & Hammer washing soda at Walmart, but it looks like a detergent.
    As always, thank you.
    Chesterfield, MO
    11,969
    Re: Testing Help?
    The PH and TA are being affected by the CYA additions, wait until that's done dissolving and then adjust the PH and TA as necessary.
    Re: Testing Help?
    Well, I'm still slowly adding cyanuric acid. Worried about the test delay and overdoing it, so it's taking me forever. Anyway, everything else is testing within normal levels. Thought I'd post some pics - water's looking good! Now if it would just get warm enough outside to swim w/o running the heater non-stop...
    Chesterfield, MO
    Re: Testing Help?
    Pool is looking great. Latest test results:
    Free CL - 4.5
    Comb CL - 1
    PH - 7.4
    Total Alk - 80
    CYA - 65
    I am worried about the CC - do I need to shock my pool? The water is crystal clear.
    Chesterfield, MO
  20. Back To Top    #20
    Re: Testing Help?
    Well that's odd. The test results I posted just above were from this morning. I thought I'd test again this evening before I got worked up about a shock and the FC was 6 and the CC was 0-.5 (when I added the reagent, the water was just a very faint shade of pink). My FC has been stable between 4 and 5 for a few weeks now. Not sure what would cause it to jump like this. And is it normal for the CC to drop on its own?
    Chesterfield, MO
