Results 1 to 9 of 9
Thread: What should I do next.
    May 2013
    Central New York
    5
    I am a new pool owner. My pool was installed late last year, so it was never opened and closed late and unforntunately had many leaves in it.
    I now have it opened and shocked (sodium Dichloro-s-Tri) the pool. I also have vacuumed a lot of debris from the pool. I have the filter running 24/7 for about 24 hours now. I have 2 test kits neither one very good as I found out today. The 6 way combo has the FC-6, TC-4, TA-90, PH-7.4, CH 50. The other test kit is a titration (I think) it test for FC-10+ and PH-6.8. I don't no my CYA, but all I've added is the shock.
    The water is still pretty cloudy, I can see the bottom of the shallow end but not the deep end.
    Should I add something to bring the PH back up or should I let it run for another day and see. Its been cloudy for the last 2 days and we have a cold spell coming.
    Thankyou to everyone that contributes to this site, what a valuable resource.
    Eric
    23K, 38x20, IG
    Pentair Sand Dollar 350lb SD-80 Filter
    Pentair Superflo 1.5HP Pump
    Vinyl Liner
    1st year of pool
    30,431
    Re: What should I do next.
    Welcome to the forum.
    I don't see a big issue with your pH but we really need to know your CYA before we can give definitive advice.
    What does your water look like?
    May 2013
    Central New York
    5
    The water looks pretty cloudy. I definately need the TFT test kit. I added like 4 bags of shock because the water was dirty from construction and not being covered soon enough in the fall, because the concrete was poured late October, and the chlorine level was 0. I was alarmed because the PH level seemed low. On the one test kit, I dont see how total chlorine can be less than free chlorine??
    23K, 38x20, IG
    Vinyl Liner
    1st year of pool
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    It can't. FC+CC=TC
    May 2013
    Central New York
    5
    Cheap test kits. If I am still getting debris when I vacuum, should I shock again, or just keep vacuuming. The difficult part is I can't see the bottom of the deep end. I truly believe FC is above 10, but again I don't know CYA. So until I know cya, I guess I just don't know anything. Any other way to know cya? Man I hate asking stupid questions that can't be answered. Now I'm rambling. I hope this pool stuff gets better. It would help if the water was clear and I could see the bottom.
    23K, 38x20, IG
    Vinyl Liner
    1st year of pool
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    You should read up in pool school, a link at the top of the page. You should do that while your are chilling out! Once you understand some of the basics like shocking your pool you will feel not so overwhelmed. You can get the water clear and it would help to know CYA levels, can you order a test kit? I would keep trying to get everything out of the pool that you can, it all consumes chlorine. Welcome!
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    May 2013
    Central New York
    5
    Thanks, test kits on order. TF-100.
    23K, 38x20, IG
    Vinyl Liner
    1st year of pool
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by harleysilo
    ^ what he said.
    Quote Originally Posted by Eric_357
    Good choice. That's the first step on the road to success in getting a sparkling pool.
    One of the basic things we teach here is that shocking is a process, not a product. Once you run your first complete set of tests with the TF-100, you will have all the information you need to determine if you need to shock (sounds likely at this point) and, if so, how to do it properly.
    PH-7.4...Should I add something to bring the PH back up or should I let it run for another day and see.
    I would leave it alone until you run your first set of tests with the TF-100. If you need to shock, I would actually lower pH to between 7.0 and 7.2 before you begin the shock process. This makes the chlorine more aggressive as a sanitizer. Then, once you begin the shock process, ignore pH - don't even test it - until you are done shocking and the FC drops below shock level. Shock level FC can skew the pH test and you may over-compensate in adusting it during the shock process.
    May 2013
    Central New York
    5
    Thanks, to everyone for their help and comments. Looking forward to the new pool and pool season.
    23K, 38x20, IG
    Vinyl Liner
    1st year of pool
