Thread: Salt System Question
    mkmscr's Avatar
    Mar 2013
    CT, USA
    45
    If I adjust the output purifier power on my Auto Pilot salt system how long does it take to get an accurate FC reading so I can tell what impact the adjustments had? Assuming I keep the filter pump run time the same I am trying to nail down my FC. This is a new pool filled a few weeks ago. Salt is at 3100 ppm and has been stable but my FC went from 2.5ppm to 10ppm in 3 days. I am assuming 10ppm FC is not safe for swimming. Do I wait it out at this point and hope the sun breaks it down some? It has been raining, cool and cloudy the last few days. Will a few days of hot sun break it down? I adjusted my salt system down by 5% to see if that helps.
    PH 7.8
    FC 10ppm
    TA 120
    CYA 50
    CC .5 maybe a little less
    17x27x37 (24000 gallons) Lagoon Vinyl liner, Hayward Eco VS Pump, Hayward 4350 DE Filter, Auto Pilot SWG, Savi LED Lighting, Maytronics Dolphin M4 Vacuum
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Salt System Question
    I would turn it down by more like 25%. You can turn it off and half your FC level will be gone with in a few days... 10 is not too high for swimming. Safe to swim up to shock level - refer to the CYA chart.
