Results 1 to 8 of 8
Thread: Long sweep 90 pressure fittings???
    Jul 2012
    Blountsville, AL
    59
    Do they make long sweep sch 40 pressure fittings? i have read here about folks using them, but don't know where you get them. I am getting parts together to re-plumb my equipment and was going to check into this before I bought normal sharp 90 fittings.
    David
    20' x 38' x 40' Lagoon, 38K Gal, Vinyl, Aqua Plus control, SuperFlow 2 hp pump, 3.7 sqft sand filter, T-15 SWG
    2 ColorLogic 4.0 LED lights, Polaris 280, TF-100 test kit, Finished in September 2012
    Master Spas Twilight 8.2
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Re: Long sweep 90 pressure fittings???
    This is what I used. Got them from Lowes.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    30,424
    Uh-oh! Time to stir up the hornets nest a bit. The are DWV 90's and not sched 40. Many here on the forum recommend that ONLY sched 40 be used. My personal take is that while DWV fittings are certainly not as strong, they are adequate for a pool.
    I have put on my helmet and am hiding under the desk waiting for the verbal beating I am about to take!
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Interested to see how this pans out. Yes it may not have a NSF-PW rating but it has worked for me. Might look into changing it if my pump will ever go out. Fingers crossed.
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    I've used those on the intake side for a few years and have not had any problems. I have gotten sch 40 sweep fittings here flexpvc.com . and use those on the pressure side. Look under PVC-Elbows-90-Sweeps
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    mas985's Avatar
    Pleasanton, CA
    11,741
    DWV fittings are not as impact resistant as schedule 40 so as long as you don't whack them or have water hammer, then they are probably ok. But I wouldn't put them on my plumbing.
    Also, replacing all the 90s in the plumbing with swept 90s doesn't change head loss by a lot. In most plumbing, it is at best a 1% change. If you are only changing the pad plumbing, it is much less than that. If you really want to change head loss, increase the pipe size. That has much more impact. A change from 2" to 2.5" results in a head loss decrease of about 9% and a flow rate increase of about 7%.
    Mark
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    If you really wanted sweep fittings, you could go to the electrical conduit aisle and get some of the gray SCH40 sweep 90s there. It's the same stuff as the white pipe.
    Jul 2012
    Blountsville, AL
    59
    Thanks for all the replies. I now have the sources for everything I need except unions. I found some Hayward unions on Amazon, but I'm not sure if they are the compact versions or not. Anyone have a good source or part # for compact unions? Lowe's only sells the huge unions and the I.D. looks small to me.
