Thread: pool is open, but...
    dahncke's Avatar
    May 2012
    Indianapolis metro area
    32
    Pool is now open, and it was this clear when we opened it before adding chemicals.
    Need to figure out how to clean the edging without washing it all into the pool (open to suggestions).
    The new heat pump is now installed.
    However---
    Kayak Pool - 12 ft. x 24 ft. rectangular, 5˝ ft. deep end
    Frog System, Sta-Rite-Modular Media Cartridge Filter, Pentair 1 H.P. pump
    AquaPRO Pro500 heat pump & Automatic AutoGuard™ Pool safety cover
    38,524
    Re: pool is open, but...
    Things are much easier to view if you imbeded the image web address into a IMG tag in the full editor like this:
    {img}www.address.pic.jpg{/img} .... using square brackets instead.
    Note it has to be the address to the picture by itself.
    I have edited this time .....
    Jun 2007
    New Jersey
    653
    I just blast that kind of thing with the pressure washer, holding the wand at an angle over the water pointing back. Some will get in the pool. but nothing the filter can't handle.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    ^ what he said.
    If your pool looked that good when you opened it, you are doing something (actually many things) right!
    dahncke's Avatar
    May 2012
    32
    Thank you jblizzle.
    BoDarville, I am really hoping it wasn't just beginners luck!
