Hello all! Everything has been running fine up until yesterday. We had a bad storm come through early in the morning. The power flickered on and off a few times before I left for work. When I left it was back on but it was raining so hard that when I did my usual pool lookout I couldn't even tell if the water water circulating. No biggie, I thought and headed to work. When I came home from work it was still raining hard. After the rain stopped I noticed the pool was not circulating. I went out to the pump area and immediately turned off the timer switch. The pump plugs into an outlet which leads to the timer. I turned the switch back on and nothing. So I checked the outlet, pushed the test button - nothing, pushed the reset button - nothing. Neither clicked in and neither clicked out. So first thought was outlet is bad. I dragged an extension cord out to the pump, plugged it in and then plugged the extension cord to a working outdoor outlet. This outlet tripped. I reset it, saw the glow light on extension cord so I plugged the pump back in, light went out again so I new outlet had tripped again. SO, do you think my pump is dead? What steps can I take from here to determine if it is infact dead? I changed the capacitor a while back, even then it hummed but didn't turn. Now it makes no sound at all.
THANKS!!
~Erin
THANKS!!
~Erin
