Thread: Filter Size Question
    Mr. Blue's Avatar
    May 2013
    Spring, TX (Houston)
    95
    New pool owner here.
    I have a Pentair FNS Plus filter, but do not know the filter size. On the side of the filter, there is a chart where the person installing the filter was supposed to 'check off' the model number (see below). As you can see, no one did this.
    The person that was "maintaining" the pool said she was told to add 6 cups of DE after backwashing. Yet, when I look at the filter, the minimum size listed is 36ft, which would call for 8 cups (based on the chart on the bag of DE).
    Is there a way to tell what the filter size is for sure?
    23K Gallon Freeform Tile Inground
    Hayward Super II 1.5 HP -- Pentair FNSP48 DE Filter @ 120 GPM
    Polaris 3900 Sport (with Booster Pump)
    Pool School Attendee -- The TF-100 Test Kit and the Pool Calculator keep my pool Trouble Free -- BBB Supporter
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Filter Size Question
    DE really should be weighed, using scoops can be WAY OFF depending on how packed the DE is.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    I had the same problem when I started.
    What I did was measure the height of the grids when I had it opened to clean it. The manual shows different heights for different sizes - all they change is the height of the grids, the center rod, and the top tank. Look at the exploded view on page 9. The parts list shows the grid heights.
    Or, less accurately, measure height of filter. Add height of top tank. That tells you how high you'll need to lift to clear the grids inside. Compare to Table 1 in that link to the manual.
    Mr. Blue's Avatar
    May 2013
    95
    Quote Originally Posted by Richard320
    Awesome. Thank you!
    I am in the process of deep cleaning the pool. I have taken the filter out and cleaned it once when I first started; I am going to do it again once I am done. I can measure the height of the grids then. Below is what the pool looked like when I started. It is now blue and cloudy...just a little bit further to go!
