Thread: Just opened in Indiana
    Jul 2012
    Seymour, In
    49
    Finished topping off the water and pulling the winter cover back and the pool looks great. Thanks to all of you here and the BBB method. Wasn't up long last summer as it was late install. Followed all the directions to get on BBB and closing.
    First readings after pulling the cover off are...
    FC - 2
    CC - 0
    TC - 2
    TA - 210
    CYA - looks to be around 38 real close to 40
    PH looks to be maxed at 8.2 if not higher.
    Next steps are?
    24x54 ABG 15,200 gal, 22in Ecco Sand Filter, 1.5HP Ecco pump
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Just opened in Indiana
    I would first bump the FC up to 3 or 4 ppm. Then, since both your pH and TA are too high, I would lower the pH to around 7.2 using muriatic acid (MA). This will also lower TA. The high TA is contributing to the high pH. Here is the complete process on how to lower TA: http://www.troublefreepool.com/pool-...l%20alkalinity. Note that it may take some time to lower TA to a point where the pH becomes more stable. At any point in this process, just make sure pH does not go below 7.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    What he said^
    Except I would go ahead and dump in enough bleach for a target of 5, since minimum is 3.
    Jul 2012
    Seymour, In
    49
    Easy enough to start with. Will be hitting the store looking for some MA tomorrow and also picking up some bleach as well. Glad I decided to hard plumb the return and also added a homemade fountain as well. Good time to put it to work to help get the PH back up while working on getting the TA headed down.
