Results 1 to 9 of 9
Thread: Compupool CPSC48...how much chlorine does it produce?
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    Having a 40k gallon pool built and nearly complete.
    The Compupool CPSC48 says it's ok for up to 60k gallons.
    I am seeing inconsistent output ratings on this unit.
    Ranging from 1.2 to 2.5 lbs/day.
    Anyone having success with this unit on a 40k gallon pool?
    Thanks.
    35k gallon 20x45 inground concrete with vinyl liner - Stamped Concrete deck
    Pentair WhisperFlo 2HP - Pentair FNS Plus 60 DE
    Heat Siphon heat pump - Compupool cpx48
    Blue Diamond RC robot vacuum - TF100 testkit
    38,261
    Re: Compupool CPSC48...how much chlorine does it produce?
    Not sure how accurate this is, but may want to look at Circupool:
    http://www.discountsaltpool.com/Full_Ma ... arison.htm
    Wish there was another resource like this that we knew was kept up-to-date.
    According to CompuPool, the CPSC48 is between 2.4 and 2.5 lbs/day of chlorine when run at 100% for the full 24 hours under ideal conditions. That is equal to roughly 3.5 gallons of 8.25% bleach. There are a couple of places that have different numbers, but CompuPool says those sites are incorrect.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Here's the NSF web site:
    http://www.nsf.org/Certified/Pools/List ... tType=50I&
    CPSC48 [4] Maximum output is 1.28 lbs/day.
    Just a comparison:
    Pentair IC40[4] Maximum output is 1.40 lbs/day.
    When I visited the Compupool corporate headquarters in Apopka, FL they said the NSF site was correct. (I specifically asked, and they looked it up.)
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    I see the specs on their site say 2.5 lb/day.
    http://www.compupoolproducts.com/produc ... aning.html
    Unless they are deliberately being dishonest, I figure that unit should suffice.
    Jul 2007
    Brisbane, Australia
    874
    keep in mind that the output is measured at specific temperature/salinity and may fluctuate with those parameters changing
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    Is the cell on the CPSC48 a true 2" ?
    I'd hate to choke the plumbing with a cell smaller than my pipe.
    Thanks
    Apr 2011
    Murrieta, CA
    2,360
    1.5 goes on the inside of the fitting, 2.0 on the outside.
    prosper's Avatar
    Jan 2013
    Taxachusetts
    57
    I called CompuPool direct and they confirmed what bobodaclown said. 1.28 lbs./day.
    I mentioned to them that the output ratings on the web indicate it produces 2.50 lbs./day.
    They responded, "We can't police every web site out there."
    I responded, "Why don't you start with your own web site, since it also states 2.50 lbs./day."
    They responded, "That hasn't been updated since 2009, but we are working on it."
    Argh....
