Thread: JVA 2440 Valve Issues
    I have a JVA 2440 valve that moves on command from the AqualinkRS, but it isn't aligning correctly. It's about 5 degrees off, which is causing other issues.
    Is it possible to recalibrate these things?
    18,000 plaster in-ground pool and spa. Pentair Inteliflo VS filter pump (replaced 2014). Raypak 260k heater (replaced 2016). AquaPure salt cell (replaced 2015), Aqualink RS controller + 2 JVAs. Jandy DEL60 filter. Polaris 280 with booster pump.
    38,251
    Re: JVA 2440 Valve Issues
    There are cams inside the actuator that tell it when to stop. Sounds like one of them got shifted maybe? Or maybe the valve needs to be lubed?
    Yeah, I that's what I thought based on some limited web searching these things.. I will try to lube it, and see if something is up with the cams.
    Thanks!
